Emergency error
Discussion in 'Man Roland Printing Presses' started by BennyAyung, Jun 27, 2025.
  1. BennyAyung
    BennyAyung Member
    Jul 2024
    23
    Jakarta, Indonesia
    Can anyone help me about this error message, its always sudenly happen
  2. drukman
    drukman Senior Member
    Mar 2016
    435
    Bulgaria
    You have problems with one of the 24V power supplies in the AX.
  3. BennyAyung
    BennyAyung Member
    Jul 2024
    23
    Jakarta, Indonesia
    I already changed the power supplies and it still happens and with the same problem
  4. drukman
    Mar 2016
    435
    Bulgaria
    Did you check the voltage after them? The same error occurs when one of the powered boards has a bad connection.
  5. CHOCK
    3,058
    Hi:
    please as say the colleague, only that you must test the secondary in the main transformer, if the VAC, are in Tolerance about 10%, and fi they are o.k test the regulated power supply very well, the tolerance must be exactly for 0.7% Up or down.
    example, if you are measuring : + 24 VDC, and you get 24.3 or more or vice versa, like 23.8 is FAULTY, the regulated power supply.
    CLEAN VERY WELL THE EDGE CONNECTOR, THESE REPRESENT THE 75% OF FAILURE IN ELECTRONIC FAILURES!
    Must be checked the Filter or electrolitic capacitor for BULGED !
  6. drukman
    Mar 2016
    435
    Bulgaria
    CHOCK, there is no 24V transformer in the Roland 700.
