Duplo error code
Chris Bristow
2020
Saskatoon Saskatchewan
Error code of F94OGOT - E immediately comes up on the start up of the machine. Shows no numbers, cant open options. Any suggestions? , this is same as someone else posted in 2019, Thanks
What model machine is Duplo Collator?
  • Hello Chock
    it is a System 2000 tower connected to a system 4000 tower. the System 200 tower has the error and that is the tower closest to the finishing end.
    Thanks for taking an interest.
    System 2000 tower
    Need the ID plate , in order to help you
    Blessing
    System 2000 tower
    Blessing
    Hi sir;
    Sorry for my delay, but was a problem with my Internet
    Try to adjust the DIP Switch C8, to ON, in order to Close the contact, N.O to N.C. and clean the rest of switch like, and look for loose wires +connectors, or corroded, or break wires.
    Hey Chuck,
    Thanks for helping everyone, you seem to know a lot!
    I have a Duplo System 5000 Collator with booklet maker and am having the same error code.
    We have two towers and when we turn them on the second tower gives us the "f940got-e" error code then shows a blank screen.
    We checked the DIP switches and they are correct.
    Let me know if you have any advice! Thanks in advance. Happy to provide any more information if needed.
    Normally wen some errors occurs, the display show how to clear the error message.
    However try to turn ON, and then OFF, wait for 1 minute. and then turn ON.
    If the problem persist, look, always, for connectors loose, dirty, oil, broken wires, bad contacts, or corroded contacts.
    Always clean the DIPS switch, with electronic cleaner contacts, very well, and the same all connectors, and tight very well all cables wire of the machine .
    Let me know, if the problem persist
    I noticed a “MELSEC-GOT” at the top right corner but other than that information the screen doesn’t display any text.
    On the second tower when machine is on it also shows an error code that “lights up when vertical conveyance board of a tower or LUL-HM conveyance board is open.” - But, the conveyance is completely closed and and have tried cleaning/checking for wires.
    Thank you for your response.
    Please do this:
    1) clean every DIP switch with electronic cleaners spray, and test if they are ok or faulty with DMM,and back to original position.
    2) If everything is ok, please Reset the CPU, in the motherboard, you must sure that VCC x CPU + Clock in MHz, are in tolerance.
    3) clean Edge connectors x electronic board, this is the cause x 70% if electronic problem
    Blessings
    Hello! Try to replace a battery in a faulty monitor
    Hello guys! I have the same issue with the Duplo 2000 Collator. It shows the following code F940GOT-E. I can't see any data on the display, so I was wondering if you guys can help me. Here is the ID plate. You can contact via email dejan_kacurov@hotmail.com
    Looking forward to your reply! Have a great day!
    It's needs a battery. If it stays there too long days/ months you may need to reprogram the board
    hello, i need reprogram board of a system 2000 collator, it shows "data is not found" please help me
    Please do this:
    Blessings
    hi¡¡ help me please , i need reprogram board for system 2000 collator, please tell me
    Look for any battery in the MOBO boards , and see if the voltage is ok, or ribbon cable or flat cable in the system where is located the Screen or monitor and test if is faulty and replace it, you must have some backup, if you do not have, you must have to order the USB unit, or CD, containing the Software.
  • Please can help me when i star the machine dsc 10/60i
    I need help please
    Whatsap :+213558707124
