Willycom
- 2018
- 6
- Australia
Wondering if anyone has had a similar problem to this.
We have a Duplo DC10 mini that will not feed any of the bins correctly.
The problem at first was intermittent and then became bad enough for us to stop using the machine.
The main board has been replaced without resolving the problem.
The machine will begin each feeding cycle on each loaded bin correctly and then stop before the sheets enter the sheet stream in the tape inside the back door to be ejected. The machine actually stops the feeding cycle after the feed rollers have completed half a turn only. If we pull the half fed paper back towards the sheet pile but not completely out from under the feed wheels, at the next start the feed wheels will turn a complete one and a half turns and feed correctly but the next cycle as the machine continues will again only feed the sheets half way just as before.
The local service people have quoted on replacing all the clutches but this is not the problem as far as I can see.
If this was the problem the sheets would not feed when the sheets are left half under the feed wheels and complete the required one and a half turns.
I hope someone has had experience with this.
Regards
Regards
