Jennings
- 2024
- 1
- AUSTRALIA
Hello James, would you please much more explain what you have done? How your technician can change the address of drives?. In the meantime, the meters were a bit aged and the durometer reading a fair amount harder than specs. We changed the meters out and those two units have not tripped off since.
We did not change the address of the drives. We changed the meter roller which was a bit aged and getting hard. It stopped overloading with the new meter rollers installed. With no real sign of the amp being faulty we looked for a mechanical, physical reason. The cups on the meter rollers were wore substantially. So, there was some play in the roller contact to the chrome when engaged. We eliminated some of the play in the contact. The idea being an uneven pressure was slowing or speeding up the rotation causing the overload. This helped but did not eliminate the problem. We installed new softer meters and have not seen a problem since. Did you first try swapping the drives from one unit to another to see if the problem followed the drive?Hello James, would you please much more explain what you have done? How your technician can change the address of drives?
Thank You very much. Good Luck... .. . Good luck and good day.
thank you for your kind feedback. i need to know how to assign address for these drives, if you know please letme know and i will give you my email address. happy to hearing from you sooner in caseIf in case you need Drives, we have Refurbhished in stock.
