Diagonal adjust
Discussion in 'Heidelberg Printing Presses' started by MRTYMM, Sep 7, 2021.
  1. MRTYMM
    MRTYMM Senior Member
    Apr 2015
    114
    egypt
    I have a problem on SM102 model 1990 with cpc1-02 machine registration diagonal problem during running, operator told me the registration on tail end of the sheet is moving especially when i use diagonal registers.. are there any ways to adjust this manually? I also have a new diagonal servo motor I don't know how to adjust to check if the error from it or not
  2. turbotom1052
    turbotom1052 Senior Member
    Oct 2008
    889
    Vermont
    Plate clamps are manually moveable, even on presses equipped with diagonal register from console.
  3. MRTYMM
    Apr 2015
    114
    egypt
    Thanks for your reply
    The machine equipped by diagonal motor xm6 ,there is no stuck with motor also it moves from console but we think that the internal potentiometer not adjusted or the motor have problem
    running a sm102 year 1990 .are thrid unit is almost always maxed out in its diagonal register. I need to know if diagonal motor xm6 adjustment to its zero or not ?how to fix the problem.?we have checked the plates and its good and the operator told us the problem from diagonal
  4. junker1984
    junker1984 Senior Member
    Jan 2010
    840
    US, Midwest
    The pin located in between the cutout in the plate cylinder bearing flange should have an equal gap, both sides of pin, at "x" readout value. I'll give you the number after i see 5,000 in bitcoin deposited into my account. I jest. I'm looking for the value.
  5. MRTYMM
    Apr 2015
    114
    egypt
    I appreciate your concern
    I don't understand . I am weak in English can you explain more clearly
    I don't know meaning of the following
    1 cutout
    2 bearing flange
    3 readout value
    I think if there picture from catalogue
    To explain it will be very well
