Deleting old curves
Zontol
2026
Australia
Hi can anyone tell me if or how you can delete old characteristic curves on a speedmaster 52 cp2000.
what curves exactly do you mean? there are several different, and you have to lock-in in service.
  • The characteristic curves in the set up menu. Where the heidelberg curve is default and cannot be deleted or changed. There are a whole lot of other curves just standard with dates when they were created by previous operators
    If you want to adjust or optimize the curves yourself, copy the original HEIDELBERG curve and edit the copy. Delete all other curves from the past settings.
    If your changes do not produce the desired result, you can revert to the original HEIDELBERG curve.
    Some buttons are only displayed if you are logged in as a print shop administrator or if the curves have been approved.
    If you want to create your own characteristic sets, give them a unique name.
    The name of the characteristic set can be the same as the name of the color series for which it is to be selected, the company name, or the machine name.
    It's been 10 years since I've run a Heidelberg with that console. The ink curves are a great tool to utilize. As mentioned by others, copy the Heidelberg curve and then make adjustments. There is a lot of guess work involved. I found it easy to adjust your curves when on a long run. You can compare your running settings to your prepress scan. If you see big differences, make adjustments on your curve, reload the job and compare again. In time you can make curves for different stocks and different line screens.
    I was told by a demonstrator that it's not advisable to adjust the speed compensation curves for ink and water.
    Good luck.
