Dampening form roller
Discussion in 'Heidelberg Printing Presses' started by Raman karthi, Apr 27, 2022.
  1. Raman karthi
    Raman karthi Senior Member
    Aug 2020
    103
    nigeria
    Dear members
    I'm running CD 74 2003, this machine dampening unit doesn't have intermediate roller, while printing dampening from roller getting too much ink. And printing coming light on the paper.
    Don't know what reason is this, any ideas most welcome.
  2. Adil
    Adil Senior Member
    Nov 2021
    867
    Casablanca
    The intermediate roller (Z) is an essential roller to have a good print quality, it is he who balances the amount of water and the ink transmitted to the plate.
    On start-up it imparts a layer of ink to the dampening roller before it takes on water and this helps to avoid unstable emulsion and you can produce with the minimum balance of water and ink.
    If you do not have this intermediate roller, the dampening roller takes the dampening solution first, which causes printing problems and in particular the unstable emulsion.
    Instagram : adilberg.tec
    asem alsafady and Raman karthi like this.
  3. turbotom1052
    turbotom1052 Senior Member
    Oct 2008
    1,054
    Vermont
    I would suggest that since you have no intermediate roller that you fully ink up your water form, instead of allowing it to pick up ink zonally. You might also want to consider using your air curtains to manage your excess water that may be contributing to your unstable emulsion.
  4. alibryan
    alibryan Senior Member
    May 2014
    220
    Somewhere
    I could go on and on about the advantages/disadvantages of integrated vs. segregated printing, but everyone has their own experience and opinions. What I will say is that there’s at least one major press manufacturer that recommends always running segregated (bridge roller off) and those presses print like there’s no tomorrow and are some of the best that money can buy.
    It’s also worth noting that old school Heidelbergs used to only come with segregated dampening systems (no z roller), and that’s the way it was for many years. However, with the advent of the ‘alcolor’ system, along came the z roller and it’s been that way ever since. Engaging it is still optional though, and I’ve run my share of jobs without it. Arguably, running with it engaged is ‘easier’ for achieving a quick ink/water balance, but in my opinion (if the press is correctly adjusted), you can produce better overall quality without it.
  5. Raman karthi
    Aug 2020
    103
    nigeria
    Thanks for your answers dears, I will follow to setup your ideas.
  6. Raman karthi
    Aug 2020
    103
    nigeria
    Ok sir, thanks, evening air also not working on All units. Already removed from the machine
  7. turbotom1052
    Oct 2008
    1,054
    Vermont
    what is "evening air?"
  8. Raman karthi
    Aug 2020
    103
    nigeria
    Sorry sir, it was a mistake in typing; I meant inking unit blowing air bar.
  9. Jack liston
    Jack liston Senior Member
    Sep 2019
    274
    Connecticut
    Evening Air is an after dinner Fart!
    junker1984 likes this.
  10. alibryan
    May 2014
    220
    Somewhere
    The adjustable slide valves on the air bar are for evening out the air. Hence - ‘evening air’!
