Cutter Perfecta UC 115 - positioning failure
Discussion in 'Cutters and Trimmers' started by oabrahim, Dec 3, 2020.
  1. oabrahim
    oabrahim Member
    Apr 2016
    59
    Venezuela
    The machine everytime stops in differents positions but the encoder was changed two years ago because in this moment the machine give a error code 33 related with a bad encoder. What can be the origin of this failure now?
  2. CHOCK
    3,089
    32- 33 error code PERFECTA 115 UC
    SAFETY SYSTEM DEFECTIVE Turn off machine !
    Safety module needs to be replaced!
    Blessing
  3. oabrahim
    oabrahim Member
    Apr 2016
    59
    Venezuela
    Thank you Sir...
  4. CHOCK
    3,089
    ok
    Blessing
  5. oabrahim
    oabrahim Member
    Apr 2016
    59
    Venezuela
    Hello, the machine was reset and the 33 error disappear. Now we have the issue: by manual positioning the backgauge stop correctly in the measure required, but in automatic mode any measure can be positioned, everytime appears error 4. Could be backgauge brake adjust? is this a electronic issue?
  6. CHOCK
    3,089
    Hi sir;
    Error4:
    DESIRED MEASUREMENT OUT
    OF TOLERANCE
    Measurement deviation >0,07mm
    Blessing
  7. oabrahim
    oabrahim Member
    Apr 2016
    59
    Venezuela
    thank you
  8. CHOCK
    3,089
    ok
    Blessing
