Curved Screen Printer, Desktop Cylindrical Screen Printing Machine
389859620
Previous User
2013
188
China
The Mini cylindrical screen printing machine is adopted imported (Taiwan) pneumatic parts with quick speed, stable quanlity, lower noise, precise over-printing, 350mm stroke. It is suitable for printing the surface of round products with 100mm diameter, such as cosmetic products, chemical container, food packing cans and other related cylindrical products. As the volume is small, the application field is wide, the price is favourable, the machine is the most popular machine in the market. It is the best favourable machine.
Feature&Specification
1. Micro-computer controlling, high degree of automation, easy and convenient operation 2. Auto 4-digit counter built-in
3. it can print round and cone products
4. In order to meet kinds of printing requirements, the printing stroke and speed can be adjusted
5. the worktable can be fine-tuning by up and down, or left and right, and flat oscillative angle, high precise printing, conveniently and quickly to adjust
6. pneumatic printing controlling with adjustable pressure system
7. stable and reliable function mirco-computer controlling
8. unaided printing and ink reclaiming speed controlled
9. with huffing function, can print soft products
10. separate special mould for round and cone products
11. action mode option: fully-automatic|semi-automatic|manual
12: start-up method: panel|padel
13. drive method: pneumatic
14. left and right drive method: pneumatic
15: vertical stroke: 125mm
16: transverse stroke: 350mm
17: max printing area: 300mm(the length of circumference or cambered surface)*200mm (width)
18: printable diameter: 5~150mm
19: if printing whole circle, the maxium printing diameter is: 95mm
20: the maxium length of printed products: 250mm
Price Terms : FOB Shenzhen or Guangzhou
Payment Terms : Western Union ,T/T or L/C
Packing : Wooden case
Lead Time : Within 3 days
Standards Certificate : ISO9001-2000,CE
Machine Fittings:
1.One aluminium screen flame
2.One Manual in English
3.One set of tool
Package List
Wooden case :
1050×850×1050mm
Gross Weight: 160kg
Ship Date
1.By sea
within 30 days after receive remittance
2.By air
within 6 days after receive remittance
Warranty
1.Cylinder can be changed for free within 1year,freight collect.
2.Other parts can be changed for free within 2years,freight collect.
3.Warranty period:3years
Company: EC Printing Machine Factory Limited
Email: sales@printer-manufacture.com
Website: http://www.printer-manufacture.com
Mini Flat Screen Printing Machine with Vacuum Table
The mini flat screen printing machine with vacuum table is adopted vacuum genertator to bring strong adsorptive power without noise. It replace manual screen printing, and solve the problems of un-stable printing quanlity, and slow printing speed by manual screen printing. The machine is small with quick speed, stable function, high precice, it can be made up of screen printing production line in small workshop. It’s special suitable for printing logo on the surface of PVC, paper, nameplate and kinds of film
1. SCM IC coordinate light touching panel to complile action programming
2. Auto 4-digit counter built-in, counting printing quantity
3. Airframe adopts coin alloy,and metal coating surface
4. distyle vertical constructure, high precision, steady operation
5. the transeversa stroke can be adjusted, spacing by Taiwan electronic switch
6. the angle of scraper and ink covering blades can be adjusted randomly
7. installing scraper constant pressure equipment to make sure pressure is steady when printing
8. you can regulate work-table back and forth or right and left, and then fastening it
9. you can regulate screen frame back and forth, right and left or level orientatio
10. vacuum stainless steel worktable, it can absorb kinds of film products
11. installing CEC oil buffer on up and down, left and righ to avoid printing shock
12. The machine is running fastly, steably and lower noise.
13. Action model option: fully automatic | semi-automatic | manual
14. Start-up method:panel | foot switches
15. scraper pressure controller:by pressure regulating Valve
16. vertical driving style: pneumatic
17. transeversa driving style: pneumatic
18. maxium printing area: 200*300mm
19. transeversa stroke: 350MM
20. vertical stroke: 160MM
21. worktable size: 250*450mm
Machine Fittings:
3.One set of tool
Package List
Wooden case :
750×850×950mm
Gross Weight: 160kg
Ship Date
1.By sea
2.By air
Warranty
  • Mini Flat Screen Printing Machine
    http://www.printer-manufacture.com/e_products/Mini-Flat-Screen-Printing-Machine-p32.html
    The mini flat screen printing machine with vacuum table is adopted vacuum genertator to bring strong adsorptive power without noise. It replace manual screen printing, and solve the problems of un-stable printing quanlity, and slow printing speed by manual screen printing. The machine is small with quick speed, stable function, high precice, it can be made up of screen printing production line in small workshop. It’s special suitable for printing logo on the surface of lens, mobile key, paper brick, small plastic products, CD box, gifts etc.
    10. T-solt worktable, convenient to install mould
    22. max height of printing products: 100mm
    23. printing workstation: 1pc
    Machine Fittings:
    3.One set of tool
    Package List
    Wooden case :
    750×850×950mm
    Gross Weight: 160kg
    Ship Date
    1.By sea
    2.By air
    Warranty
    Tabletop Rotary Screen Printing Machine Rodless Cylinder
    Model:EC-1015R
    1.Max printing area: 110*150mm;
    2.Worktable size: 120*120mm;
    3.Transverse stroke: 400mm;
    4.Vertical stroke: 100mm;
    5.Rotray table diameter: 400mm;
    6.Max height of product: 50mm;
    7.Rotary table workstations: 2pcs/4pcs;
    Application
    Mini high speed rotary screen printer, using cam divider high speed rotary table, improving production. The speed
    is 2000pcs/hr. Printing, feeding and baiting at the same time with high speed and very stable function. It's a
    desktop style, easy to operate, suitable for printing the surface of mobile shell, lighter, plastic shell, metal
    shell etc flat products printing.
    Technical parameter:
    1. IC with touch panel program action programming;
    2. Aluminum casting body with metal coating;
    3. Auto 4-digit counter, calculate printing quantity;
    4. Double pillar up/dowm struture, making sure precision and stable;
    5. Transverse stroke can be adjusted, using Taiwan sensor to limit;
    6. Squeegee, flood bar can set as any angle;
    7. Squeegee constant pressure, keeping printing pressure stable;
    8. T-slot worktable, convenient to install jig;
    9. Installing CEC buffer, making sure printing stable;
    10. Action mode: auto | semi-auto | manual;
    11. Start up: panel | pedal;
    12. Squeegee pressure control: pressure regulating valve;
    13. Vertical driven: pneumatic;
    14. Transverse driven: electronic;
    15. Max printing area: 110*150mm;
    16. Worktable size: 120*120mm;
    17. Transverse stroke: 400mm;
    18. Vertical stroke: 100mm;
    19. Rotray table diameter: 400mm;
    20. Max height of product: 50mm;
    21. Rotary table workstations: 2pcs | 4pcs;
    Tabletop Screen Printing Machine with Carousel
    http://www.printer-manufacture.com/...reen-Printing-Machine-with-Carousel-p669.html
    Model:EC-1015C
    Application
