CPC 104 errors TSK 2 and BEK 101
Maestro
2019
Ghana
Hello guys.
I have TSK 2 and BEK 101 errors showing up on the Display. Ink zones and register motors aren't working.
Any help.
Please test the 1) power supply +5+12+24 : a) register b) ink motors
1a)test the battery in the board BEK
2) see if the Green Led is LIT, otherwise test the fuse
3) test the plug connector in the secondary side of transformer, that control electronic board, for loose, dirty, or damages cables or wires.
4) Finally replace the control board motor.
  • Unfortunately I've tried all the possibilities but the error wouldn't go away.
    I've changed the GSM board, replaced the TSK and the BEK.I Have changed the entire MAR unit with different set of cards from another machine.
    The error still remains.
    Please do this 1) in the secondary Tap Transfer Measure with 10% of Tolerance:
    X1: Plug- Pin base input voltages
    1 24V AC
    4 24V AC
    5
    6 24V AC
    7
    8 28V AC
    9
    10 24V AC
    2) X2: Plug- Pin base input voltages
    Pin Function
    7
    20V ac
    13
    14 20V AC
    10
    12 27V AC
    8
    15 15V AC
    2 20V AC
    5
    9 17.5V AC
    11
    6 17.5V AC
    3 not assigned
    3) If everything is o.k in the 2 steps before go to the next steps in the GSM Rectifier Module
    X3 Socket base output voltages
    Pin Function
    1 24V DC
    3 24V DC
    5
    6 24V DC
    7
    10 28V DC
    8
    9 24V DC
    X4 Socket base output voltages
    Pin Function
    5 20V AC
    6 20V AC
    8 27V AC
    7 15V AC
    X5 :Socket base output voltages
    Pin Function
    3 20V AC
    1 17.5V AC
    5 17.5V AC
    6
    4) Now measure with a Good DMM :NTE board power supply very well, the tolerance must be 4% up or down
    Power supply board for 12V DC
    Power supply board for 8V DC
    Power supply board for –8V DC
    Power supply board for 24V DC
    Power supply board for 5V DC
    How you must understand, IF ANY of the Voltages show in the 1+2+3+4 is a) missing b) or out of tolerance, the cpc will NOT work, you can replace ALL the electronic board, and Always will be have the same problem. o.k??
    Do carefully and with Patience.
    Gentlemen thanks for your help on the CPC.
    The fault was with the MWE cards.I changed 2 of them and the errors did not show up again.
    Thank you
    hello i have same problem motors works and registers works only led on the table not illuminate i dont know where the ink motor is at
    i have problem with cpc1-04
    fza8 no led illuminat i check 5v 24 to bek its okay
    the buttons works motor moves registers no problem all okay
    only led not working
    on zid no errors shows
    i reset the motors from the screen ZID THE MOTORS gose to 0 postion and it knows thats in 0 so there is feedback from tsk i think no problem between tsk and bek
    Are you also a repair technician?
  • Hi sir:
    1 24V AC
    4 24V AC
    5
    6 24V AC
    7
    8 28V AC
    9
    10 24V AC
    Pin Function
    7
    20V ac
    13
    14 20V AC
    10
    12 27V AC
    8
    15 15V AC
    2 20V AC
    5
    9 17.5V AC
    11
    6 17.5V AC
    3 not assigned
    Pin Function
    1 24V DC
    3 24V DC
    5
    6 24V DC
    7
    10 28V DC
    8
    9 24V DC
    Pin Function
    5 20V AC
    6 20V AC
    8 27V AC
    7 15V AC
    Pin Function
    3 20V AC
    1 17.5V AC
    5 17.5V AC
    6
    Blessing
    superchock@yandex.com
    i checked all the voltage its all okay
    the cpc all functions is work unless the led FZA8
    the fza8 gose to bek directly the xilin controller control them and have eprom
    bek board dosnt have voltage comparator it can work without 10%tolerance
    i changed tsk still same problem
