cp 2000 over heat?
Discussion in 'Heidelberg Printing Presses' started by andrysetio, Feb 7, 2012.
Tags:
  1. andrysetio
    andrysetio Member
    May 2011
    49
    indonesia
    my cp2000 screen black out suddenly, i think it is over heat
    need break around 5 minutes then turn it back on
    then after an hour or two it went black again
    anybody with solution?
  2. Paul Cavanaugh
    Paul Cavanaugh Senior Member
    Dec 2009
    630
    Kennesaw, GA
    Out of curiosity, what is the temperature of your shop?
  3. andrysetio
    andrysetio Member
    May 2011
    49
    indonesia
    around 30 celcius, i'm using air conditioned but seems a bit short
    now i open the table top it never shut down
    but not a very good sight
  4. Paul Cavanaugh
    Dec 2009
    630
    Kennesaw, GA
    Typically the room should be no more than 23 Celsius. High temperatures have been known to cause electronics in cabinets which are not cooled to have intermittent issues.
    If it is working when you have the cabinet open, it proves the point.
  5. LLS northwest uk
    LLS northwest uk Senior Member
    Nov 2011
    93
    Northwest UK
    I have seen this before just make sure if its cp 2000 it should have fan and filter on the front of it make sure its working and the filter is clean
  6. Mathew
    Mathew Senior Member
    Apr 2010
    579
    Kolding-Denmark
    Adding to LLS, if CP2000 computer is MC2 or MC3, you have to check the fans on the case. If the seal on the case is broken, open the case, clean inside with dry compressed air carefully and then run it again. If not, check it with Heidelberg. As I know Heidelberg had a general call few years ago for the computers, maybe your press is on the list.
  7. andrysetio
    andrysetio Member
    May 2011
    49
    indonesia
    i dont see any air outlet from the body. i see one fan from left compartment to right under the computer
    but no hole to the outside
    i plan to make hole and install a fan, but kind of worried
  8. Mathew
    Apr 2010
    579
    Kolding-Denmark
    Since the fan is sucking air from out and blowing inside the case, there is no need for the air outlet. Did you check the case? Is it sealed or not? if not, open it and clean inside as i explained before. I did it several times on different machines and they are still running.
  9. Waqas_zahid
    Waqas_zahid Senior Member
    May 2011
    239
    Pakistan
    I would take a look inside and see if the IPC shows any sign of life. Our shop is at around 30 C as well. Sounds like a back-light problem to me. Does the screen flicker or anything?
  10. andrysetio
    andrysetio Member
    May 2011
    49
    indonesia
    No There is no problem With the screen
    Now I add more air conditioner so now around 24 c
    The cp works fine, but if it is a long day work and it's getting warmer
    It still turn off occasionally. I just have to rest around 15 minutes to make it works again
  11. Mathew
    Apr 2010
    579
    Kolding-Denmark
    Good to hear, but it would be better if you could change IPC. It's a common problem in MC2 and MC3 generation. MC4 is more reliable.
  12. andrysetio
    andrysetio Member
    May 2011
    49
    indonesia
    Hello mathew
    I've seen your history
    It seems youve been experienced the same problem
    How much do you spent to replace the ipc?
  13. andrysetio
    andrysetio Member
    May 2011
    49
    indonesia
    What ipc looks like? Haha sori kind of amateur
    Anybody have picture? If it is broken what is the sign?
  14. andrysetio
    andrysetio Member
    May 2011
    49
    indonesia
    Does the ipc means the computer under the cp2000 screen?
    Man it's gonna cost a lot, I already ask Heidelberg for the system it cost 20.000 us dollar
  15. Mathew
    Apr 2010
    579
    Kolding-Denmark
    Yes you are right, it costs a lot, but I had repaired three of them. They have been running for three years. If you know a good engineer, I can help you to repair it.
  16. andrysetio
    andrysetio Member
    May 2011
    49
    indonesia
    How can you help?
    You mean idont have to buy the whole ipc?
  17. Mathew
    Apr 2010
    579
    Kolding-Denmark
    Yes, I mean you don't need buying a new IPC.
  18. edipelangi
    edipelangi Member
    Mar 2014
    12
    indonesia, jakarta.
    hello all,
    it looks loike i ahve the same problem, just installed the sm 52-4. and already using external display.
    but the problem is, when i turn on the cpc, the display dont show and the ink control light only show for 5 seconds, after that is off.
    please help. thanks.
  19. ahmed elsebaie
    ahmed elsebaie Member
    Aug 2015
    13
    saudi arabia
    hello Mathew
    i have same problem in my SM52 machine
    would you please tell me how to repair the IPC to not turn off the monitor
  20. Mathew
    Apr 2010
    579
    Kolding-Denmark
    Hi,
    What's the problem? Give more details.
    Regards
