ali 120
- 2023
- 106
- Egypt
What is the correct measurement between the print cylinder holder and cover cylinder holder when separating the print and during printing?
And where is the side pressure indicator located when measuring?
There are more than one specialized technician with different opinions.
Some say to set the side gauge to 0, then measure between the print cylinder holder ring and the blanket cylinder holder with a 0.50 filler.
Then, between the blanket cylinder holder ring and the lower cylinder holder ring, measure with a 1 mm filler.
This measurement should be used for all cylinders without printing.
Others say to set the side gauge to 0, then measure between the print cylinder holder ring and the blanket cylinder holder with a 0.10 filler. All cylinders should be in the printing state.
Then, between the blanket cylinder holder ring and the lower cylinder holder ring, measure with a 0.35 filler.
Which is more accurate for the manufacturer's factory settings?
