Connections for external counter/ signal output
Discussion in 'Heidelberg Printing Presses' started by Andrew123, Dec 5, 2016.
Tags:
  1. Andrew123
    Andrew123 New Member
    Westrock
    Trying to figure out best practice to capture sheet count both gross and net good sheets,along with press speed.
    Using PLC's from opto 22 to capture signal,just not sure where to connect to the press.
    Will be for 1999 CD 102 with CP2000
    2004 XL105
    2009 XL105UV
  2. eng reda
    eng reda Member
    Feb 2012
    17
    egypt
    from SAM interface in main cabinet
    point 42-43 for good sheets and 40-41 for net count
    check attached
  3. Andrew123
    Westrock
    Perfect!!
    Thank you very much.
