Color sequence for best quality?
Discussion in '4-Color Offset Presses +' started by veenaayarora@yahoo.com, Oct 19, 2012.
  1. veenaayarora@yahoo.com
    veenaayarora@yahoo.com Member
    Oct 2012
    19
    India
    Dear All,
    Please let me know which is best Sequence or combination for best result in 2 Color Machine or 4 Color Machine?
    Regards
    Veenaay Arora.
  2. Bill Borcicky
    Bill Borcicky Senior Member
    Jul 2012
    214
    U.S. Amory, Ms.
    For most 4-color machines I had found the best color image results to run black, cyan, magenta and yellow. I have tried other combinations, however the best comes from this sequence.
  3. NotAGooner
    NotAGooner Senior Member
    Dec 2007
    279
    UK
    I always ran K Y first then C M on a 2 col press, more control over the color that way and it always matched the matchprint.
  4. veenaayarora@yahoo.com
    Oct 2012
    19
    India
    thanks i also try both soon.
  5. Huzie
    Huzie Member
    Apr 2013
    6
    Mexico
    I had also tried K, C, M & Y or K, Y, C & M. Important thing that Black is the only color, which makes a good combination with the other colors.
  6. lukegpl
    lukegpl New Member
    May 2013
    faridabad/ Haryana
    For 2 color machine: there are many color like white with black, red with white, blue with black.
    For 4 color machine: black+ white +green+ light+ blue
  7. Giangngo
    Giangngo Member
    Nov 2018
    10
    Vietnam
    What do you base on to decide the color sequence?
  8. mantman
    mantman Senior Member
    Nov 2015
    289
    Greece
    Depends on your inks and their respective tackiness, also if you have solids with cyan+magenta or the other way around you can change the order to get better results, but as far as i have read until now, i think the best in 4 cols is KCMY sequence. You get better traps at colors RGB
  9. Giangngo
    Giangngo Member
    Nov 2018
    10
    Vietnam
    I read many documents: When they print more than 2 colors with 'wet-on-wet' offset printing, the following color's thickness is thinner than the previous color's thickness. Why? And if I printed 'wet-on-wet', would 2 adjacent colors have been mixed together?
  10. Important thing that Black is the only color, which makes a good combination with the other colors.
  11. turbotom1052
    turbotom1052 Senior Member
    Oct 2008
    1,092
    Vermont
    When you say "thinner" are you referring to less tacky? If so then that is in theory true. When printing multiple colors, anywhere that you have 2 or more colors overprinting each other the tackiness of the ink should diminish from unit to unit. If you were to assign a tack number of say 18 to the black then all following colors should have tack numbers descending. For example... when printing k,c,m,y your tacks numbers should start at 18 and finish up with the last down yellow at 15. This would be preferred in order to optimize trapping. Ill use the old peanut butter and jelly analogy here because it defines it in simplest terms. Its very easy to spread a big blob of jelly on top of the peanut butter that's already been spread on the bread. But if you were to spread the jelly on the bread first think of what would happen if you were to try spreading the peanut butter on top of the jelly!!! The same applies with ink trapping.
  12. davidrobin85
    davidrobin85 New Member
    Jun 2019
    NYC, USA
    I also tried K, Y, M
  13. georgbob
    georgbob Member
    Jul 2019
    26
    Hungary
    K M C Y, when Lab value date the priority
  14. Mbangi
    Mbangi Member
    Sep 2019
    5
    Pretoria
    Hi all my sequence on a 2 colour machine is run C,M first and then K,Y. And on a 4 colour I prefer K,C,M,Y .worked like that always and it worked for me
  15. sunildhamecha
    sunildhamecha New Member
    Nov 2011
    INDIA
    Yellow is the only color which generates brightness and shine in printing, so it should be kept always last stage to avoid wiping of ink in blankets and loosing shine and brightness according to me KCMY always gives the perfect results, also have tried CMYK but KCMY give much more brighter output
