color question. ink tips??
Discussion in 'Offset Papers & Stocks' started by micahnelson, Jan 13, 2010.
  1. micahnelson
    micahnelson New Member
    Jan 2010
    home and on the roam
    Im Printning some business cards with a very limited supply of ink.
    i have decided to use a dark gray-ish card stock paper for this particular card.
    the problem is due to my limited supply of ink I am unable to test my colors
    and see how they differ from digital to how they appear on the dark grey stock.
    The most important color in this design is green. Actually, almost the entire design is based on the color green.
    so i simply need to know that if i put the color green in my business card software, is it going to come out brown on the paper??
    Maybe i should use a bright yellow as the gray has a bluish tint to it.
    ANY advice on this color problem or any tips on saving ink will be greatly appreaciated!!!
    Thank You,
    Micah Nelson
    ___
  2. plotter
    plotter Senior Member
    Feb 2009
    376
    south wales uk
    why do you have a limited supply of ink? for me to print anything, whether digital, litho or wide format, i always have more than enough ink to do the job twice??
  3. Albuq. Henry
    Albuq. Henry Member
    Aug 2009
    28
    Albuquerque, NM USA
    usually if we were printing on a dark paper we would add some opaque white to the ink it might take some playing tho to get it right. some pms's you just wont be able to mach on certain stocks.
    Now what you say about trying a different color ink on the colored paper and getting what you want because the two mix will work sometimes.
    On yellow paper we always run rubine red to make a bright red.
    but with your paper = gray.... I dont what you mix with gray to get green....
    In you situation I would try the opaque white. we mix sometimes up to 50/50 the pms and white.
  4. nosefo
    nosefo Member
    Aug 2009
    23
    Norway,Stavanger
    You have to print this job in two steps. In the first run use a copy of the green plate. Print the Opaque white with a thick enought layer so you cover the grey paper. Then in the second run overprint the white field with your special green color. Let the green logo bleed just a little bit so you cover all the white if you have problem to achive a perfect register. Good luck:)
    Elly Ragot likes this.
  5. timc
    timc Senior Member
    Aug 2009
    104
    leicester
    printing on any dark papers will need a white (opaque) underprint
    Colours will look much better ,the better the white is
  6. turbotom1052
    turbotom1052 Senior Member
    Oct 2008
    1,100
    Vermont
    if you can find a color thats close in the metallic book you will have the opacity required to not be nearly as affected by the color of the stock. On an uncoated sheet there will be a much diminished "metallic" effect.
  7. Throne
    Throne Member
    Nov 2010
    13
    SoCal USA
    Foil might be your best option
  8. Data
    Data Senior Member
    Jun 2010
    121
    uk
    Why have all the trouble? Use white card and print the green and the grey
