In cases of heavy coverage , the dryer's heat can make the ink boil under the coating and crack.
With heavy images , the top skin of theink will dry due to the heat , andunder that , the ink will boil and come out resulting with cracks.
It is much better to use the air knife to dry the top skin and not IR , then you will not get the cracking result , but it will take longer to dry and only smaller stacks.
If you are using IPA in your water system , you may have it too high , resulting with higher mixing rates of water in your ink , and then theink will boil even more and the only way to solve this is to go down sharp with the IPA or use extra air knife power.
With UV , you should not get this as the UV light will go in and activate a proccess that will dry the ink completelly with time (not instant as some think)/
How are you printing ?
