CMYK work on Single Colour Press
Discussion in '1-Color and 2-Color Offset Presses' started by cybershafs, Nov 10, 2009.
  1. Dino67
    Dino67 Member
    Jun 2009
    5
    Trenton NJ
    I've been Running 4c process, with Poly plates, on our Hamada e47 for a few years now. I run KCMY,I run the Black and Cyan in one pass,Then single passes for the Magenta and Yellow. I usually run the the stock through Dry first, I've found that when I go to run the Magenta it seems the paper either stretched or shrank,running it through dry,without printing seemed to help alot.
  2. turbotom1052
    turbotom1052 Senior Member
    Oct 2008
    1,070
    Vermont
    i would suggest having color keys made this way you can match the color keys with each press pass. i would strongly discourage running the yellow first because yellow alone on a sheet is very difficult to see. try to save the most dominant colors for last
    also you dont want to let the job sit around long between passes. if you can get all 4 colors on the sheet in a single day do it like that
  3. cybershafs
    cybershafs Member
    Nov 2009
    8
    South Africa
    Thanks Turbotom1052
    i ran a job today and started with the yellow, got to cyan and realised we had fountain solution problems.
  4. print101
    print101 Senior Member
    Feb 2010
    55
    S.A, Cape Town
    What fount problems???
  5. cybershafs
    cybershafs Member
    Nov 2009
    8
    South Africa
    the usual, scumming etc. heres the thing i also wanted to raise. I get my chemicals from a supplier in concentrate form. I mix it according to generic label on bottle. thing is how does my supplier now what my municipal water conditions is. ie iv got to test my ph and conductivity etc here rather.
