Change the v belts of Roland machine 708
technician
2013
18
philippines
Hello guy's can any body help me how to change the v belts of Roland machine 708 main motor it's 14 PC's belts.thanks
  • the first step is realease the tension of the V-belts then remove each one from pulley. you must replace all belts same size and brand you must not mix, then you must use a frequency meter for measuring the tension for all belts. I need more information about your press like model and serial because the value can change a little bit betwen serials
    Speed alighment is also what you need to do after changing belts...
    Machine is roland 708 with perfecting .
    Machine model R708 manroland s/n33023B release the bolt from the frame of motor or realese the tension of the pulley of the belt.this is my first time to change the v belts of roland.thank you
    ok it´s a serial 750 or more, then it´s a High Print machine, there is a basic adjustment for the tension of V-belts using a dinamometer, you must pull each belt using a force of 50 Newtons with a deflection of belt of 8 mm. I´m enclosing a picture of the basic adjutment.
    there is another method using a frecuency meter, you must use a formula for calculating the initial frecuency of your belts, you can download information about this procedure from continental ...
    can you please show where the bolts is to release the tension of the motor if you have picture of the the bolt much better.thank you
    sorry my friend , I have no pictures of the mechanical side but any mechanic could figure how to release the tension of belts and then replace it.
    as you see the motor is mounted over a plate with a hinge fixed to machine wall. there is a nut that you can screw it in order to lift the plate! you only have to rotate the nut clockwise! just pay attention to mechanism should be another nut that fix the plate first you have to loose one nut then is possible to lift the plate !!!
    normally is an hex nut M24, so you must use a spanner 24 mm
    you must go under printing unit 1 and at the wall inside machine, you can found the M24 hex nut in a hole trough the wall , you must found hex nuts fixed together in order to leave the shaft immovable
    Hello sir can you please give me idea on how to dismantle the lower plate clamp of roland 700 machine,because the clamp is always open its not closing,
  • 8 bolts 10mm.
    It is more difficult to dismantle the clamping system
