Ceramic tile arm
Discussion in 'HP Indigo Digital Presses' started by jetscreamer, Sep 19, 2022.
  1. jetscreamer
    jetscreamer Senior Member
    Apr 2009
    137
    Kenilworth australia
    What is the ceramic tile wizard in the monthly maintenance. And where is the ceramic tile arm?
  2. White rabbit
    White rabbit Member
    Apr 2013
    71
    USA
    press model ?
  3. jetscreamer
    Apr 2009
    137
  4. White rabbit
    White rabbit Member
    Apr 2013
    71
    USA
    wizard allows you to clean the ILD lens. the lens is under the 3rd door back on the exit conveyor inside the exit door
  5. jetscreamer
    Apr 2009
    137
    So I just lift up the 3rd door in and I should see a white ceramic tile? The wizard opens a cover. I assume I clean it with alcohol.
  6. White rabbit
    White rabbit Member
    Apr 2013
    71
    USA
    the arm (cover) is the tile. yep clean with ipa.
  7. jetscreamer
    Apr 2009
    137
    Awesome, thanks.
