CD74 after a year why have bearers of blanket and plate cylinders worn?
Discussion in 'Heidelberg Printing Presses' started by hossein, Feb 15, 2017.
  1. hossein
    hossein Member
    Feb 2017
    8
    Iran
    Hi
    Last year I installed a CD74 but after a year I realized that the bearers of blanket and plate cylinders have been worn.
    Can anyone tell me why this happened and what should I do?
  2. aqazi81
    aqazi81 Senior Member
    Oct 2009
    827
    KARACHI PAKISTAN
    May be too much impression pressure and for not cleaning the bearers daily. Also if the machine wasn't leveled precisely.
  3. hossein
    hossein Member
    Feb 2017
    8
    Iran
    Thank you for your answer. Can you tell me more details if I send you some photos of bearers?
  4. mrheidelberg
    mrheidelberg Senior Member
    Jan 2008
    761
    United Kingdom
    How do you know they are worn ?
  5. hossein
    hossein Member
    Feb 2017
    8
    Iran
    I checked that.if you have whatsapp I can send photo of bearers
  6. mrheidelberg
    Jan 2008
    761
    United Kingdom
    Sorry don't do whatsapp.....can you just add a picture on here so other people can see & comment on it.
  7. hossein
    hossein Member
    Feb 2017
    8
    Iran
    Here there is a photo of bearer which has been worn
  8. exheidmech
    exheidmech Senior Member
    May 2009
    674
    USA
    While not impossible its very rare to have the bearers actually wear to the point of having print related issues on a CD74. What are you seeing on the sheet? Have you indicated the bearers using a 0.01mm dial indicator or one that is more accurate? Bearer surface is extremely hard and I have seen more often that they crack vs wear.
  9. hossein
    hossein Member
    Feb 2017
    8
    Iran
    I see strips on sheet.
  10. exheidmech
    May 2009
    674
    USA
    Who has told you that the streaks you are seeing on the sheet is being caused by worn bearers? Streaks are most commonly caused by incorrect plate to blanket pressure, incorrect roller settings or tight gears. Have you checked roller settings? Has anyone tried to adjust plate to blanket pressure? Do you find that you are having to use excessive back cylinder pressure to get the machine to print correctly? Are you using low quality blankets? Roller settings and trying a quicker release blanket are likely the cheapest checks before getting into more costly fixes. I find it unlikely that your steaks are being caused by work bearers.
  11. hossein
    hossein Member
    Feb 2017
    8
    Iran
    Bearers of plate and blanket cylinders in each unit have been worn.Can we reduce the pressure on bearers of blanket and plate cylinders or pressure on bearers is fixed?
    Do you know the main reason?or which parts should be checked to find out why they all have been worn?
  12. exheidmech
    May 2009
    674
    USA
    Special tool is needed to reset bearer pressure on CD74
  13. hossein
    hossein Member
    Feb 2017
    8
    Iran
    Do you have an article Or something else about resetting the pressure on bearers of blanket and plate cylinders?
  14. turbotom1052
    turbotom1052 Senior Member
    Oct 2008
    1,054
    Vermont
    Id save the bearer adjustment for someone more qualified even if you had the tool. The fact that the picture you posted that looks normal to me, is seen as a worn bearer, tells me that you're probably not qualified to do the rather intricate adjustment. Not trying to be a dick here just saying.
  15. exheidmech
    May 2009
    674
    USA
    The bearer pressure tool used to reset and check pressure is a specialty tool used by Heidelberg technicians. Any attempt to readjust pressure yourself will likely not end well for you. My suggestion is to have a Heidelberg tech come in and evaluate your machine and reset pressure if its needed. I think you will find this is going to give you the results you are looking.
  16. hossein
    hossein Member
    Feb 2017
    8
    Iran
    Thank you very much
