CD102 error
Discussion in 'Heidelberg Printing Presses' started by mick.cullen, Aug 17, 2016.
  1. mick.cullen
    mick.cullen New Member
    Aug 2016
    New Zealand
    Hi,I have a CD102 five colour and it is coming up with the error DWBA Movement lock main drive. Rebooting does seem to clear this error but sometimes it requires up to 3 reboots. Any ideas as to what might be the cause.:mad:
  2. PKT FDO
    PKT FDO Member
    Oct 2014
    36
    battaramulla-srilanka
    Dear friend,
    this is a safety error.some one put hand or leg in to the delivery pile machine stop automatically, now see your delivery you can see red lights on delivery.now you press reset button on middle of delivery ,lights turn to green colour. now you can start the machine again.no reboot required.thank you-Kosala Fernando.
  3. mick.cullen
    Aug 2016
    New Zealand
    Hi Kosala, Yes you are correct normally however this is happening sometimes whilst running but can happen whilst stopped. No one near the machine so no barrier broken. The red lights do not come on. Also seems to only happen early in the morning.
  4. Mathew
    Mathew Senior Member
    Apr 2010
    533
    Kolding-Denmark
    Hi everyone,
    How old is your machine? Let us know if error pops up in blue or red color!
    It's probably malfunction of DIPM2 module in delivery control box. I have seen this error several times.
    Good luck
  5. mick.cullen
    Aug 2016
    New Zealand
    Hi Mathew,
    The error pops up as red. Can you describe the exact location of this DIPM2 module or give me a Heidelberg part number so I can replace it?
    Machine is now approaching ten years old.. Regards Mick Cullen
  6. Mathew
    Apr 2010
    533
    Kolding-Denmark
    Hi Mick,
    It's located on the top of delivery inside push button control box. Find it and write down the exact part number from itself.
    By the way, only DWBA error pops up or you have other errors like safty and limit switch errors as well?
    Good luck,
    Mathew
