Cd 74 running with vario off
Discussion in 'Heidelberg Printing Presses' started by Jack liston, Nov 3, 2022.
  1. Raman karthi
    Raman karthi Senior Member
    Aug 2020
    103
    nigeria
    Dear sir,
    I want to understand Why we have to keep 7 mm with vario and 5 mm with out vario?
    How it is working? And what is the changes in the various pressure?
  2. Raf77
    Raf77 Senior Member
    Aug 2023
    253
    United Kingdom
    Because roller mustn't be driven by plate.
    Why do you want running pres with vario off? What's the reason?
  3. Adil
    Adil Senior Member
    Nov 2021
    1,252
    Casablanca
    Hi sir
    the role of the vario system is to reduce the speed of the dampener to half compared to the speed of the plate cylinder in this way we obtain friction on the plate which can eliminate the fizz
    Good luck
  4. Adil
    Adil Senior Member
    Nov 2021
    1,252
    Casablanca
    If you check my answers in the forum you will find the role of intermediate roller between ink and dampending system , it important to regulate the balance between ink and water also it avoids unstable emulsion at start-up ,
  5. Raf77
    Raf77 Senior Member
    Aug 2023
    253
    United Kingdom
    A half???:eek:
  6. Adil
    Adil Senior Member
    Nov 2021
    1,252
    Casablanca
    Yes sir not exactly half but less than a half i mean low speed .
    So vario mode is preselected at the control station
    When we print with the vario system stopped the dampening device works like a standard dampening device on the other hand if we put the vario system ,the degreaser E drives the dampener toucher 13 at low speed. due to the differential speed between 13 and the plate, a formation of sparkles on the plate is avoided.
    Be welcome
  7. Raf77
    Raf77 Senior Member
    Aug 2023
    253
    United Kingdom
    So there is a half of speed or not exactly?:)
    I know what is Vario for and how is it working. But you must realise that because you give not true informations, you may cause problems for some young and unexperienced guys.
  8. Printman673
    Printman673 Member
    Sep 2023
    31
    Virginia
    I'm pretty sure it's closer to 20% slower could even be less it's been awhile, but it also helps with hickey's/ paper dust on the plate the slower speed allows it to potentially drag them off. Also vario off will make speed up your water oppose to in where as the form roller is spinning slower which will add more water to your plate if that makes sense.
  9. Raman karthi
    Aug 2020
    103
    nigeria
    Sir, I'm just asking for understanding the working principal of Vario system.
    So we can use keep on always with vario mode, right?
    And with vario mode dampening form roller and distribution roller pressure should be set 7 mm or can be less than that?
  10. Raf77
    Raf77 Senior Member
    Aug 2023
    253
    United Kingdom
    Yes, you can run with vario always on.
    Settings must be 7-8 mm
  11. Raman karthi
    Aug 2020
    103
    nigeria
    Ok sir thanks for the advice.
  12. Raf77
    Raf77 Senior Member
    Aug 2023
    253
    United Kingdom
    No problem at all
  13. Adil
    Adil Senior Member
    Nov 2021
    1,252
    Casablanca
    Hi sir
    in my last post I translated to the letter what I learned from the specialist engineers in Heidelberg, they say that the vario system works with low speed, I said at the beginning half because I am French speaking and I can't figure it out i can't speak very well in English, unfortunately the admins of the forum prohibit other languages which blocked me a lot from sharing information with the language that I master perfectly.
    otherwise the speed of the vario is not really required, you just need to know that it runs at a slow speed and what you need to know is the thickness of the contact strip which must be adjusted.
    THANKS
  14. Raf77
    Raf77 Senior Member
    Aug 2023
    253
    United Kingdom
    Ok, ok Adil, didn't want to raise your blood pressure:)
    In my opinion that's good that we use one language - can you imagine if every one of us speak different language? That would be new tower of Babel :D
  15. Jack liston
    Jack liston Senior Member
    Sep 2019
    313
    Connecticut
    Agreed please remember that running various on all the time will shorten the life of your water form rollers.
    asem alsafady likes this.
  16. Raman karthi
    Aug 2020
    103
    nigeria
    Dear sir,
    So when can on Vario and when keep off vario?
  17. Raf77
    Raf77 Senior Member
    Aug 2023
    253
    United Kingdom
    Vario is for remove hickeys. You can keep it on all the time. But if you really want to play about this then turn it off when you're printing just text or jobs with no pictures/solids
  18. Raf77
    Raf77 Senior Member
    Aug 2023
    253
    United Kingdom
    What have you done?:D
  19. Adil
    Adil Senior Member
    Nov 2021
    1,252
    Casablanca
    if you work with a dusty surface the vario system will be useful to you, I advise you to work with it all the time it is an option that you must exploit it
  20. Adil
    Adil Senior Member
    Nov 2021
    1,252
    Casablanca
    no no I love these little comments and critical thinking is what pushes us to improve and give our best and above all to seek and train all the time.
    I will always be at your disposal for any instructions or remote troubleshooting.
    Be welcome
