CD-102 Feeder Timing Issue
Discussion in 'Heidelberg Printing Presses' started by Mike Jimenez, Jan 31, 2025 at 1:23 AM.
  1. Mike Jimenez
    Mike Jimenez New Member
    Friday
    Carmona Cavite Philippines
    Good day guys, please help on my issue on feeder timing, when i run the machine it always stop before the 2nd paper goes in on the feeder. But when i try using inching button and feed the paper no problem on feeding paper. Hope that some experts here could notice this post and assist, Thanks..
  2. junker1984
    junker1984 Senior Member
    Jan 2010
    1,112
    US, Midwest
    Model year? What have you done relative to troubleshooting and adjustments to attempt to solve problem?
    Mike Jimenez likes this.
  3. Adil
    Adil Senior Member
    Nov 2021
    1,243
    Casablanca
    Hi sit
    maybe the adjustment of the photocells, also the adjustment of the air passage on the margin table if you are sure that all this is good check the pneumatic cylinder for opening the balance clamps, the latter for me is the most possible.
    Good luck
  4. Mike Jimenez
    Friday
    Year 2015 Model, already checked and tried what's on the trouble shooting guide and all are okay but still nothing works, we will try to replace this front lay solenoid valve because we saw there's an air leakage from this part.
  5. Adil
    Adil Senior Member
    Nov 2021
    1,243
    Casablanca
    Yes that s what i told you is the most possible for me , this is for openning the balance clamp .
    Good luck
