Hello! My problem still remains.
I though the problem is the prnt head. So there is another one. After reinstaling it, it started filling with ink, then it it calibrated and everything was ok. for 2-3 drawings. then the black disapeared again.
So i though the problem comes from the right pump which handles BK and MBK inks.
If I strat procedure for replacing the ink, it will suck the ink from the PF, then reinstall the same PH, it will fill it up, calibrate and another 2-3 perfect drawing will be done, but this is not the sollution.
The firmware is changed to v1.50
In service mode there are no menus for refiling or something else.
There are no stored errors or warnings.
Also I tried to reconect the cable connections between the right ink station and the mainboarb but still nothing.
ANY IDEAS?
here it is a file with all the setting that comes out from the printer. If somebody see something not right, please help!
Iliyan
