C6500 machine,Toner stick on the drum,how to fix this problem?
shawn Xia
21
Shanghai,China
This problem makes me crazy.the toner always stick on the surface of the drum(like spot or dot).after I clean it,it looks running well,but several hundred prints later,it comes again.
how can I do?someone told me it is the toner problem,but I change many times,still the same.
maybe a charger problem or fuser problem, does the toner stick to card or is it flaking off, ofen it wil be on the back of the next sheet if its the fuser? are you using oem drums and toner? try changing drum
  • thanks for your reply.I upload the photo which the drum looks like.I use the DU102c drum,not the oem drum.
    the first thing i would do is change the drum and see if this eliminates the problem. cant be the cleaning blade or youd have a line all around the drum in the same place.
    the life of this drum is only 7%, I change it at last week. it could not be the problem of the drum for sure.
    oh yes it could, did it happen before you changed it, if not im affaid it is the drum
    Ever since they fixed the blade flip issue, the drums have been %#@$^&#@.
    I run into this problem once a week on this machine.
    Replace the drum and return it to the manufacturer.
    get oem drums and you wont have the problem, the prints will also look better. same goes for toner get oem and youlll soon see the difference
    I had the same problem with RICOH MP9000 OEM DRUM and Toner always used. From the picture looks like a generic drum is used. Is it? I think I had traced the problem to the drum cleaning blade as it is pretty much the only thing that presses against drum with somewhat pressure. If you're running low coverage jobs or say, almost "0" cyan or any particular color that you're having a problem with, this could be created by extra friction, keep in mind that toner on drumblade also lubricated the point of touch. Do this - clean the drum or take a new one and run 5-10 sheets of that color. Simply create a band of 100% Cyan or whatever in iA and print some of that. See if problem will comeback and if issue fill be affected overall. I think I got the problem after running something like a letterhead with image only on the top all day long - 25,000 sheets. Printing a dozen or so sheets will lubricate a drumblade surface that engaged in cleaning and should illuminate the problem... In case I am right, for a future, if you know that your images are low on some color, run a few bands once upon a time...
    I have the answer
    It is not often i say this, but I know what is wrong.
    When you install a new drum, it has two screws (usually red) that need to be taken out from the drum itself. These screws stop the cleaning blade from cleaning the drum, it is there so the drum doesn't get damaged during transportation. Just take out the security screws from the sides of the drum unit.
    I know this because this problem crippled my business for months.
    You can use drum from konica 6000 du-104. They are lasting more and thet are cheper.
    Hi, i believe they will be releasing a new du-102 drum soon. This will resolve the toner spotting issue. In the meantime you can request from the manafacturer a modified cleaning blade which will resolve if you have a spotting issue. Please note that the machine needs new firmware installed if a modified blade is installed. This firmware will also be required for the new drum coming out and if you fit a DU-104
    Thanks for all.but can you tell me what is the version of the newest firmware?
    Hi,
    The firmware is Image control program/Print Control Program Ver. GN3-70). There are also Dip switches that need to be set which enhance the cleaning control for the drum.
  • Forum posts represent the experience, opinion, and view of individual users. The Color Printing Forum does not necessarily endorse nor share the view of each individual post. When making any potentially dangerous or financial decision, always employ and consult appropriate professionals. Your circumstances or experience may be different.
