I had the same problem with RICOH MP9000 OEM DRUM and Toner always used. From the picture looks like a generic drum is used. Is it? I think I had traced the problem to the drum cleaning blade as it is pretty much the only thing that presses against drum with somewhat pressure. If you're running low coverage jobs or say, almost "0" cyan or any particular color that you're having a problem with, this could be created by extra friction, keep in mind that toner on drumblade also lubricated the point of touch. Do this - clean the drum or take a new one and run 5-10 sheets of that color. Simply create a band of 100% Cyan or whatever in iA and print some of that. See if problem will comeback and if issue fill be affected overall. I think I got the problem after running something like a letterhead with image only on the top all day long - 25,000 sheets. Printing a dozen or so sheets will lubricate a drumblade surface that engaged in cleaning and should illuminate the problem... In case I am right, for a future, if you know that your images are low on some color, run a few bands once upon a time...
