Brake sticking on Feed Table Hoist
Discussion in 'Komori Printing Presses' started by ChrisH, May 28, 2013.
  1. ChrisH
    ChrisH Member
    Apr 2010
    19
    US
    Does anyone have any information on how to properly adjust the brake on the Feeder Pile Hoist Motor on a Komori NL 528. Ours is sticking and we cannot get it adjusted correctly.
  2. Meny
    Meny Senior Member
    Apr 2008
    772
    Israel
    Brake should be ON/OFF and nothing more
    As far as i know (and i do not know your brake or it's history) it is very basic , and the device is pre-adgested.
    Will it keep the motor in braked condition and not release it or will it not brake the motor (so it slips down and fail to climb up ) ???
    Do you wish to change the speed the table moves up ?
    Meny
  3. ChrisH
    ChrisH Member
    Apr 2010
    19
    US
    The table will only move in auto. It won't move up or down in manual
  4. Meny
    Meny Senior Member
    Apr 2008
    772
    Israel
    what is the logic then ?
    If the brake is working in AUTO and not working at all in manual why do you think the problem is in the brake ???
    If the brake stops the table from slipping down when fully loaded and releases the table to go up in auto mode , then nothing wrong with the brake !
    Plain logic....
  5. Meny
    Meny Senior Member
    Apr 2008
    772
    Israel
    you may have a PLC issue
    Tye brake is a mechanical device with 2 ways - open / closed
    if it is OK in auto mode , it can not be wrong mechanically
    So the problem may be in the PLC controling it (bad diode on board ?)
    If i remember right , you should have (in the original PLC) 2 diodes that are not in use.
    If it is the diode , you can use one of them for a faster respons , but this is for an electric engineer who knows what he is doing to check....
    can't answer this in remote
    Good luck
    Meny
  6. presselectronics
    presselectronics Senior Member
    Oct 2011
    150
    North America
    I agree with Meny on the brake, if the feeder pile works properly in Auto, the brake is probably not your problem. The key word here is properly! How many impressions do you have? Has the brake ever been adjusted? If the press is several years old and you have not adjusted the brake, it may be time to do so. Most of the newer Komori's brakes are spring loaded and you merely tighten the 3 crush nuts (metal version of nylock) 1-2 faces evenly. The exact gap should be in your manual but I'd guess around 0.2-0.3mm.
    As for PLC failure, not likely. Almost all of the feeder pile circuitry on your press is relay logic, limit switches and sensors. Do the contactors pull in when you push the up/down button? Does the motor get hot?
  7. ChrisH
    ChrisH Member
    Apr 2010
    19
    US
    The brake was the problem. Replaced it and it works just fine. Thanks for the help
  8. klecman
    klecman Senior Member
    Mar 2009
    171
    New York
    An important yet often overlooked element of the hoist brake circuit is the brake capacitor. As the brake disc wears, the distance between the pressure plate and magnet increases to the point that the magnetic field can no longer overcome the force of the springs pressing the pressure plate to the disc. A deteriorated capacitor can accentuate this problem because it no longer provides the initial electrical 'kick' to pull the pressure plate from the disc.
    Adjusting or replacing the brake will temporarily correct the problem but if the capacitor is failing, the problem will soon return as the disc begins to wear and the capacitor deteriorates further. Replacing the capacitor is an inexpensive preventive measure.
    Visual signs of a failing capacitor are the presence of leaking electrolyte or swelling of the capacitor.
  9. klecman
    Mar 2009
    171
    New York
    I have one new - old stock JPE MSB-140 feeder hoist motor brake for Komori or Mitsubishi 40 inch press left in my inventory. Asking price is just over half the list price. Includes capacitor and warranty.
    ah6k@warwick.net
