ballykea
- 2008
- 184
- Pennsylvania
Perfect Binder Retail (including Spine Taper) price is $52,750 - now only $19,450 USD
Programmable Drill Retail price is $22,750 including Electric Drill Sharpener - now only $10,450 USD
New in 2016 Model Phoenix Automatic Perfect Binder-CE Rated
Show machine. Only made 200 books. Excellent condition. Able to extrude EVA or PUR-spine & sides. Simple set-up.
• Extruded PUR and EVA applications for spine & side
• Sealed glue systems - odorless with NO fume emissions
• Designed and manufactured in Italy
• Book size min./max. L x H: 4 ¾” x 4 ¼” / 15” x 15”
• Cover size min./max. 4 ¾” x 8 ½” / 15” x 27 ½”
• Block/spine thickness up to 2”
• Cycles: 200 per hour
• Milling equalization (single sheet) 0.5 mm
• Milling depth (folding paper) 2 mm (optional)
• Fiber opening tools - special low residual dust emissions
• Paper chip suction device
• PUR/ Hot Melt for gluing milled or sewn book spine-no emissions
• PUR/ Hot Melt - for gluing one or two sides of book block – individually selectable - no emissions
• Capacity of tank PUR/ Hot Melt – 2.2 Lbs.
• Cut-off glue settings - spine and side
• Automatic cleaning of glue applicator unit
• Nipping station: “self-adjusting”
• Power requirement: 220V/single phase-50/60 Hz-3 Kw
• Machine dimensions: L 4’ – H 3 ½’– D 2 ½’
• SPINE TAPER INCLUDED
Machine Weight: 530 Lbs.
One (1) Concorde 3 Drill with Single Head
• Includes Programmable Hyper Table
• Ability to program and store 100 jobs
• Includes optional Foot Pedal for operation
• Minimum distance between holes: 8mm
• Motor: 0.9HP; 220/380V; 3 Phase
• All tools and manuals
• Drilling Depth: 70mm
• Drilling Thickness: 40mm
• Drill Sizes: 1/8” to 9\16”
• Net Weight: 308 Lbs
• One (1) Electric Drill Bit Sharpener – included at NO CHARGE
These machines are like new with about 8 hours of use. Six-month warranty included.
Contact SpecSys
ballykea@gmail.com
Contact SpecSys
ballykea@gmail.com
