You gonna… smear your… underwear! (or make a facepalm)
Because I found the problem and also the solution!
I was searching for parts for imaging units to order one set to sort out the possible problem, as suggested.
I made a list but before the order I decided to make every possible maintenance what is written on the troubleshoot pages and every maintenance on the web, which mentions blur and applies for my unit.
I done two things:
1. I cleaned the LED assy lens.
This maintenance is actually mentioned in the service manual and in
this YT video. So I did it according them.
2. I cleaned the electrostatic charger wire (At least I think so):
In the previously mentioned video the lady also fiddles with the some white plastic sticks under the toners.
I did the same on my unit. I am not sure that they are the same thing in my case because the sticks in my unit haves different shape, color and they are a part of the imaging units.
The service manual didn’t mention any “electrostatic charger wire” only some “charge corona” so I dint know about it.
I don’t know which of these helped but the blur almost totally disappeared! Just the cyan makes still a little blur, so I give him another two cleaning strokes but that didn’t help anymore.
I never did this cleanings before. Firstly because I didn’t know about them, secondly because even after I uploaded the troubleshoot pages which ones mentioned blur, nobody suggested that possibility and thirdly… I never imagined that the previous owner would miss a simple thing, such as a non-invasive cleaning process.
Probably I will have to repair/change the LED for the cyan in LPH assy (or the charger wire/corona) in the future but for now, I am fine with it!
I answer your question anyway.
The blur was present from the beginning. I bought this unit this way in the hope that I will figure out how to repair it (just like with every used broken electronic I bought). The last owner told me (as he remembered) it slowly developed the blur, and then they lost the patience to maintain it further and put it in the heated archive/storage where it stayed 2 years.
I got some items along with it when I bought it:
1 used waste toner bottle
1 used paper dust remover (I think)
1 new ozone filter
1 used deodorant filter (I think)
1 nearly empty yellow cartridge
2 full/new black cartridges
I checked the local markets for compatible used/broken unit selling for parts. No interesting listing currently.
Hopefully I can squeeze out of it 100000-150000 pages before I will have to replace something (probably the first things will be ozone filter, dust remover or transfer roller) but before that I will probably change the LED or wire of cyan color after all, if any of those causing the remaining blur and if can find any compatible parts. Sadly I didn’t find any replacements for those so far.
So far found replacement for drums
here an
here as a 5 piece bundle,
chips,
belts (which I am not sure about the compatibility currently). Also found an image transfer unit for 280 but I like the idea more where I have to replace just the belt. Just have find a compatible one or figure out which models using the same belt.
Anyway, the mystery of the blur is solved for now. I hope this topic will helpful for others also. Probably I will return to this topic time to time.
Thank you guy for all the help/time you spent for helping me. If you visit our county says hi! I pay a round
