beginner questions
Discussion in 'UV' started by Cicili, Feb 7, 2020.
  1. Cicili
    Cicili New Member
    Feb 2020
    Pula
    Hello everybody,
    I'm new here and I bought a new printer so I have a few questions.
    So far I used an old solvent printer based on epson 1290. now I bought a Chinese uv 3360 printer.jpg
    uses one epson xp600 printhead.
    So let's start with the questions:
    1. I have no need for white ink in my work, do I even need to put it into the printer? since the printer has no white circulation and the mixer I will only have problems.
    2. is there any rip software I can use other than the one that comes with the RIPPRINT printer?
    this rip does not allow me to send to print from other programs which is important to me considering all the preparation I have for an old printer?
    3. Can I use alcohol to clean my printer instead of my UV cleaner?
    because I don't know if I'm going to get one since I'm still waiting for liquids
    4. In general what should you look out for in maintenance? any advice welcome.
  2. Wappy
    Wappy New Member
    Jun 2020
    UK
    Hi
    How did you get on with this printer? I've ordered the same.
    Was you able to find the answer to questions by using it, as I too have the same questions?
    Thank you
  3. Cicili
    Cicili New Member
    Feb 2020
    Pula
    hi,
    You need to fill all ink.
    I haven't tried any other rip program yet.
    I got a uv cleaner with the printer and am using it for now.
    The white color clogged me very quickly even though I used it and did everything according to the instructions.
    It prints nicely when you get used to it and find the ideal settings for yourself.
  4. Wappy
    Wappy New Member
    Jun 2020
    UK
    Many thanks for your reply! It's rare to come across anyone that has actually used/owned this printer and you are the first I've found. Good to hear that at least it's working nicely once you get used to it.
    How did you unclog the white color?
    I've also ordered UV cleaner, but having no experience with this type of printer (or even solvent print), what is the process of the cleaner, in that sense that do you run it through the actual printer to flush out ink/clean printer head, or is it simply used in general such as to clean the wiper blade etc?
  5. Cicili
    Cicili New Member
    Feb 2020
    Pula
    Some operating instructions will come with the printer. Contact the technical service they will give you videos with instructions so that part is nicely explained.
    I didn't unclog the white color, it's most likely a problem in the print head. of course they will not admit failure. for my job I don’t need white so I don’t bother too much.
  6. Imprimerie Kagena Vision
    Imprimerie Kagena Vision New Member
    Sep 2024
    GOMA
    Hello. My UV is showing OFFLINE when I push the nozzle bouton. It's not printing.
  7. Imprimerie Kagena Vision
    Sep 2024
    GOMA
  8. Adil
    Adil Senior Member
    Nov 2021
    1,350
    Casablanca
    What did you mean by uv , is it a uv machine or offset with uv unit
  9. Adil
    Adil Senior Member
    Nov 2021
    1,350
    Casablanca
    Please give more details to know what kind of problem you have ،or take a video to know really what happend
