I wanted to take a look at all of the colors by separate but we don't have it. I wanted to make sure there is not a pip problem, if it's a pip problem, this mark should only appear in two colors, but you say appears in any color so if that's the case, it would seem a problem with the second transfer, take a look at the teeth of the drum, that there is no tooth broken or dirtiness between them, also, adjust your first transfer.
