Davino
- 2026
- 50
- Los Angeles, Taipei, and Riga
A general technical question on matte UV varnish application:
We've settled on matte varnish flood coat with image knockouts on Arctic Volume White 130gsm, LED-UV press. The stock's pleasing natural tactile surface has already been significantly altered by the press process itself it seems – perhaps the nip pressure, dampening, UV cure, or calendering – so we're not starting from pristine mill samples. But we'd still prefer the lightest effective coat possible.
Two questions:
1. Is the "plasticky" feel associated with some varnish coats primarily a function of coat weight, or varnish formulation independent of weight? In other words, can a lighter coat of a standard formulation suppress gloss effectively while feeling less like a polymer skin?
2. Is there a minimum effective coat weight below which matte UV varnish gives incomplete or patchy gloss suppression on coated matte stock? I need enough to reliably kill text glare on body text and fine 8.5pt annotation text, but no more than necessary.
Has anyone run tests at different coat weights on similar stock, or successfully run two zones at different weights on a proof sheet for comparison?
Two questions:
