1. The Color Printing Forum Marketplace Forums can be useful for members who know one another well from forum discussions and offline communications and wish to post presses, equipment, or parts they either want or have for sale or trade. However, caution and good judgement should always be used. Especially when considering any business with anyone not already well known to you and trusted, due diligence must be used to confirm details and identity and be sure the transaction is safe before any money or property changes hands. Always use good judgement and perform due dilligence and follow these guidelines.
Automatic Labeling Machine for Double Sides
Discussion in 'Other Printing Equipment for Sale' started by ecprinter, Aug 11, 2023.
  1. ecprinter
    ecprinter Member
    Nov 2014
    44
    ShenZhen
    [​IMG]
    Application
    Double Sides Labeling Machine is applied to label square bottles , round bottles or flat bottles with double mark
    or single mark., as liquid shampoo bottles, mildy wash bottles.hand washing bottles , small cartons etc.
    Features
    1. Labeling height and angle are adjustable.
    2. Power spacer separates containers into fixed space.
    3. Conveyor belt and labeling speed are adjustable.
    4. Top Hold-Down Conveyor supports containers stand vertically.
    5. Controlled by Microprocessor system with LED screen.
    6. Labeling counter, easy to manage.
    7. Specifically selected sponges flap labels after labeling to make labels attached perfectly.
    8. Advanced detection system makes precise labeling.
    9. Labeling speed is synchronized with conveyor belt.
    10. The conveyor belt meets MCC standard.
    11. Emergency stop button.
    12. All are made of stainless steel and high quality aluminum alloy.
    Specification
    1.Label width: 20-160mm
    2.Label length:20-200mm
    3.Products Size:
    Length: 20mm-250mm
    Width:30mm-90mm
    Height: 60mm-280mm
    4.Max Outside diameter of label roll: φ280mm
    5.Inside diameter of label roll: φ76mm
    6.Labeling speed: 70-100pcs /min
    7.Accuracy of labeling:±1mm
    8.Power: 220V/110V 50/60Hz 1200W
    9.Machine Net Weihgt : 350KG
    10.Machine Dimension: 3050mm x 1500mm x 1600 mm
    [​IMG]
