Anti-offset Powder
Discussion in 'Print Glossary' started by Color Printing Forum Admin, May 12, 2007.
  1. Color Printing Forum Admin
    Color Printing Forum Admin Administrator
    Jul 2006
    319
    A fine powder sprayed over the printed surface of coated paper as sheets leave a printing press to prevent ink from offseting from one printed sheet to the back of the next while wet. Anti-offset power allows printing on media that is more difficult for the ink to quickly dry on.
    Presses commonly time pulses of power to each emerging sheet.
    IR dryers can reduce the need for powder.
    Careful ink choice can also reduce the need for powder, but at the cost of other ink properties and price for quick drying inks.
    Anti-offset powder is also termed dust, offset powder, powder spray, and spray powder.
  2. imaysloh
    imaysloh New Member
    Nov 2007
    malaysia
    if too much anti-offset powder been used, what the result?
  3. bluebeep
    bluebeep Member
    Jan 2009
    11
    England
    You name it you will get it. Too much powder too many problems to list.
    buildup of powder on feeder
    ...........of powder on running in wheels causing marking on succesive runs
    ...........of powder on back cylinder
    ...........on grippers causes sticking grippers causes all sorts of hassle
    DEPENDS WHAT GRADE OF POWDER IS USED 1B is the usual for general work
    ALSO MAKES YOUR TEETH FALL OUT BECAUSE ITS MOSTLY ICING SUDAR
    Makes all old minders like me look like the old boy out of film with Bogey
    Called treasure of sierra Madre Ha Ha
    Dont use too much better to run small stacks no worries then
    Regards BLUEBEEP
  4. RichardK
    RichardK Senior Member
    Aug 2007
    685
    Derby, UK
    Sugar spray is very receptive to damp and can easily congeal in pipes, nozzles etc, but it is good for products that are going to be laminated, or for multi-pass work.
    The trick with any powder is to use just enough to prevent setoff.
    And thinking about the term isn't it Anti-setoff powder not Anti-offset? Leastways that how its always been sold here in the UK - maybe it's different across the pond.
  5. wijayasharon
    wijayasharon New Member
    Aug 2009
    indonesia, south east asia
    offset powder
    how to know wether it's enough using or not? tq..:confused:
  6. RichardK
    Aug 2007
    685
    Derby, UK
    Run small pile, reduce spray, check for setoff if OK reduce spray again, run small pile, reduce spray, check for setoff.
    Repeat until you get slight setoff and then up the spray a little. Continue with small piles and check.
    Tedious but essential to ensure no over/underspray.
    Goes for any spray powder.
  7. wijayasharon
    Aug 2009
    tq for the reply. i'm gonna try it today. :)
  8. madjock
    madjock Member
    Mar 2010
    11
    vancouver bc
    I too believe that the correct term is anti set off powder, at least that is what is says on the boxes that the stuff comes in here in Canada, but people strangely insist on calling it offset, which as far as I remember is the process of lithography that we generally use, as opposed to direct lithography, ie the image is not offset via a blanket
  9. adamwatson
    adamwatson New Member
    Mar 2015
    India
    I want to know how much offset powder shall I use for printing small sheet?
    Thanks in advance...
  10. aqazi81
    aqazi81 Senior Member
    Oct 2009
    827
    KARACHI PAKISTAN
    Minimum sufficient to prevent sett off. Select proper micron size and type for your substrate.
    Read the post by Richardk.
