Air leakage from solenoid valve
Discussion in '4-Color Offset Presses +' started by Raman karthi, Sep 19, 2023.
  1. Raman karthi
    Raman karthi Senior Member
    Aug 2020
    103
    nigeria
    Dear senior members,
    I'm running CD 74 2002 model.i have the problem with the machine, is leaking too much air from solenoid valve,
    How can find out the problem, is it pneumatic cylinder or solonoid valve problem?
    How can find out this?
  2. Raf77
    Raf77 Member
    Aug 2023
    77
    United Kingdom
    Swap the valve with another unit and you'll see straight away
    Sometimes you just need pull the pipe out, cut out a little bit and push it back
  3. Raman karthi
    Aug 2020
    103
    nigeria
    Sir, you mean, remove the valve and fix it another unit?
  4. Raman karthi
    Aug 2020
    103
    nigeria
    How can find that pneumatic cylinder leakage?
  5. Raf77
    Raf77 Member
    Aug 2023
    77
    United Kingdom
    Just tell me what's the problem? Which pneumatic cylinder isn't working?
    If you'll swap the valves you'll see - if cylinder is working - that's the valve is broken.
  6. Raf77
    Raf77 Member
    Aug 2023
    77
    United Kingdom
    Yes
  7. Raman karthi
    Aug 2020
    103
    nigeria
    I have the problem that, too much air leakage in solonoid valve place, I couldn't find which solonoid valve is leaking, because there's lots of valve.
    How can find the leakage valve from the list?
  8. Raf77
    Raf77 Member
    Aug 2023
    77
    United Kingdom
    First just check if all the pipes are in place, just push them in one by one. Then check if all valves are tightened enough - there are 2 phillips screw on each.
  9. Raman karthi
    Aug 2020
    103
    nigeria
    Ok sir I will check the 2 things first and let you know.
  10. Raf77
    Raf77 Member
    Aug 2023
    77
    United Kingdom
    Good luck pal
  11. Adil
    Adil Senior Member
    Nov 2021
    655
    Casablanca
    Hi sir
    do you work with the scrollstar of the machine or a separate compressed air installation??
    reassure yourself that it is not air escaping from the air chamber behind the air distributors. Do you have this leak in all the groups or only in a single printing group?.
    Let me know
