terrymcv
ABG OMEGA DIGICON SERIES 3
- Unwind Unit to take reels up to 800 mm diameter
- Servo-rotating Flexo Printing Station for full-coverage coating
in Quick-change version with Teflon-coated ink fountain, ceramic anilox roller,
rubberised duct roller with squeegee, rubberised coating roller
(width 325 mm, repeat length 279 mm)
- GEW UV-Dryer Model E2C (140 Wt/cm) with air cooling.
- Servo-driven semi-rotary Punching Station with 25.5" magnetic cylinder
semi-rotary insert, automatic pressure switch, servo drives for precise
registration to print mark, automatic longitudinal adjustment, manual
transverse adjustment, Servo drive for the semi-rotary function,
Servo Drive of the nip roller for the rotation mode with pneumatic pressure,
magnetic cylinder 25.5" is included, others are possible in the range 12" to 25.5"
- Servo-driven stamped grid winding with a maximum roll diameter of 800 mm;
- Servo-driven product winding with a 76 mm pneumatic shaft with possibility
a front and rear winding, precise tape tension control, max roll diameter 600 mm
with a label counter;
- Central control panel with software on a sliding console.
Including following options:
- Vetaphone Corona Treater model CP01 with integrated controls and ventilator
for conductive and non-conductive substrates
- FMS line guide sensor (allows both edge and line guide)
- Up charge from full rotary flood flexo to re-register rotary station
- Up charge from full rotary re-register flexo printing station to semi rotary
flexo print section complete with driven semi rotary shuttle
- SEMI AND FULL ROTARY FLEXO PRINTING MODULE
- ULTRA-FINE REGISTER CONTROL FOR FLEXO SECTION (+/- 0.15 mm)
- Slide in/out carriage for ink cartridge to ease loading/unloading
- Hot Air Dryer for priming/coating/water base/printing on the width 320 mm
- 1,5 m base section for extended flow out
- De-lamination/re-lamination attachment (excl. web turn bar),
- Additional equipment including Nip, non-stick roller and reverse sensor
- Web turn bar (on the Rail)
- Low inertia chill roller for full rotary web motion only
- Servo drive to chill roller for semi rotary web motion
- 5 kW chiller for up to 3 lamp system
- OVER LAMINATION STATION (on the Rail)
- Re-register for over lamination
- SERVO DRIVEN FLAT BED SCREEN PRINTING MODULE
including a GEW E2C UV Drying Unit
- Electronic Dispro Software
- Overhead mounting rail charge (per converting section) – 4 pc.
- RAZOR BLADE SLITTING ATTACHMENT with 5 holders
- Razor blade holder with blade
- Pack of 10 razors
- Venturi trim extraction -up to 16 trim width.
- Lower position rewind with 76 mm air shaft
- 152 mm over sleeve for 76 mm parent shafts
- 6” slip differential mandrels
- Remote access monitoring/support for electronics
- Additional sets of anilox rollers:
165 lpi x 50micron (18,13 cm3/m2)- 1 pc.
200 lpi x 40micron (14,02 cm3/m2)- 1 pc.
240 lpi x 34micron (11,94 cm3/m2)- 1 pc.
300 lpi x 22micron (7,58 cm3/m2) - 1 pc.
400 lpi x 14micron (4,74 cm3/m2) - 1 pc.
SYSTEM PRICE: CURRENT OWNER ASK FOR OFFERS
- Pack of 10 razors
