7500 Indigo not keeping pips
Discussion in 'HP Indigo Digital Presses' started by kodiakbear421, Feb 25, 2013.
  1. kodiakbear421
    kodiakbear421 New Member
    Feb 2013
    Indiana, USA
    About a week ago, we started losing pips on the older of our two presses. We have cleaned the pip clamp, replaced the cleaning station motor, replaced the charge roller, swapped the cleaning station with the working press as well as the charge roller. the pip is not coming out of the clamp. it is being pushed to the non operator side of the machine. we have a new pip clamp on the way but I'm looking for other ideas as we have rebuilt or swapped everything out that could possibly be changed, as well as going through 4 lots of pips, to find out what the problem is.
  2. graphiccenter
    graphiccenter Member
    Jul 2012
    11
    Guam
    Is your problem resolved? It's most likely your clamp. It could get weak on one side forcing it to go the other direction.
  3. kev9000
    kev9000 New Member
    Oct 2013
    West Yorkshire
    We had this problem also. A new pip clamp cured it. Make sure the FSE changes the pip clamp for you as it is a bit tricky to remove.
  4. digitaldoll
    digitaldoll New Member
    Nov 2013
    chesapeake virginia
    if you are still having issues, check the IO flow. i went through i couple clamps but the real issue is the flow calibration
