628 counter and speed not working
Discussion in 'Komori Printing Presses' started by stateprinter, Oct 30, 2019.
  1. stateprinter
    stateprinter New Member
    Mar 2016
    washington,usa
    Counter not working press speed indicator jumping all over does anyone know where sensor is located?
    lwhiskars likes this.
  2. stateprinter
    Mar 2016
    washington,usa
    Update this problem turned out to be bad brain in feeder Komori calls the vericam
  3. lwhiskars
    lwhiskars Member
    Jan 2014
    15
    spartanburg south carolina usa
    Just started have the same problems hit and miss.
  4. stateprinter
    Mar 2016
    washington,usa
    Check vericam that is what caused our problem it is brain in back of press behind same door that has switches when you change over side guides
  5. lwhiskars
    lwhiskars Member
    Jan 2014
    15
    I did happen to see the varicam screen go blank for a few seconds and come back on for alittle bit and do it again cut off for 2 or 3 seconds and repeat
    Thanks I'll have to check on one of them varicams.
  6. stateprinter
    Mar 2016
    washington,usa
    as far as I know it is a komori only item and has to be programmed we have a great electrical guy and he programmed it from old one + you need to know how to 0 press mechanically on timing so be aware it is not just plug and play with the new one but we have had no issues with ours since new one was installed.
