Asif Qazi, why do you think Heidelberg would be a better choice?
Because I worked on Heidelbergs and you can print any substrate from thin paper to heavy board through the CD or XL.
Heidelberg has a very reliable alcolor dampening system and its very easy to understand.
Best thing about these presses is the transfer cylinder system, You get almost no marking on sheets. This helps really in heavy board.
I don't know much about the Komori but as far as i know older komori presses had the transfer cylinder system that is prone to marking, Meny can advise you better on Komori.
As far as print quality is concerned, both presses produce top quality.
If I had a choice to make I would definitely go for the Heidelberg.
In our country there have been quite a few new installations of KBA Rapida and I'm quite amazed with the performance and print quality.
both mskes make good presses that cost alot.
any printer around the world will give you his opinion according to what he knows - the press he operates.
it all comes down to the jobs you have and the printer that will stand by the press.
I think Komori are better presses but the people who make them are very hard to understand.... Jap's.
What kind of service is best in your area ?
this will be one of the main factors i think as you are not in the center of the world and service could be a problem.
good luck
in my country it is 90% Heidelberg , 5% Komori and all the other options are 5%.
The Heidelberg presses need alot of service & parts while the Komori presses need much less , as long as the operators keep the instructions by the book.
In my country the Heidelberg is dominating the market and service and parts are not a problem here. Any press that you buy, if properly maintained and you do the scheduled maintenance, down times are very rare. Electronics are a totally different issue, one electronic board goes faulty and you can be down for a couple of weeks.
