3302 ink fountain roller not turning correctly
If I thin the ink out the roller seems to turn OK. Is there a clutch or what part is not working correctly when this happens... I dont have a part or service manual....
Which fountain do you have? They came with a step less fountain (has a dial for ink control)or a lever with like 7 positions?
  • 91706 one way clutch hf1616,stepless.
    90355011 one way clutch hfl 1626 stepless. It could be the pawl 529051070 and ratchet wheel 534051053-2 on the stepped fountain.
    The clutches are for the stepless only. When you press them use a wood block or something soften the covers have a tendency to give a little.
    If you have a stepped fountain those clutches will not work . On that unit it's a bushing so the pawl and ratchet wheel is most likely worn out.
    On the operation side it has a badge that should say 3302h or 3302 ha or 3302m. The part number I gave you is for the m however I can get the ha and ha numbers if needed.
    Mr Mark it is the M so im going to order the clutch an want to thank you for your help. Thanks again I really appreciate you helping me out. I will let you no how I made out..
