3050 ITM Overheating
Discussion in 'HP Indigo Digital Presses' started by HowieW, May 30, 2017.
  1. HowieW
    HowieW Member
    May 2017
    5
    UK
    We have come in today and started up a 3050 and the itm is overheating. On further inspection it seems the itm lamps are staying on all the time, so the itm is heating up whilst the machine is in standby. The itm temperature is going up and can been seen on the display doing so, soI don't think the fault lies with the senosr.
    I have powered down to the wall cleaned the itm sensor but still the same.
    Any help would be appreciated
  2. member 17759
    member 17759 Member
    Apr 2017
    13
    China
    There are two options for this error:
    • A non-calibrated IR temp sensor – for that you need to confirm with external sensor and
    then recalibrate or replace it.
    • Connection problem between the carbon brushes and the sliding rings. This may be due
    to coating on the sliding ring and carbon brush tips
  3. member 17759
    member 17759 Member
    Apr 2017
    13
    China
  4. member 17759
    member 17759 Member
    Apr 2017
    13
    China
    Hi Howiew
  5. Evgeny
    Evgeny Member
    Apr 2017
    7
    Russia
    If "the itm lamps are staying on all the time" in standby mode it seems like a software bug. Can help restarting press or restoring press configuration. If no, then need to check connections between carbon brush connectors and RIT, then connectors 8P and J23:
    Also you can check if there is a problem came from thermostat or "connection problem between the carbon brushes and the sliding rings" by shorting two cables, which connected to carbon brushes (Before do that, be sure to lamps is off on a standby mode!).
