OCEquipment
- 2016
- 0
- Orange County, California
Description
The Yawa TD1060S automatic die cutting machine is a high performance professional grade die cutter with stripping capabilities. The possibilities are endless with the Yawa TD1060S which can easily replace numerous outdated machines due to it’s versatility enabling you to crease, emboss, deboss, die-cut and more. It is equipped with the latest technology that will not only increase your production but give you the edge against your competition.
Details
Manufacturer: Yawa
Model Number: TD1060S
Year (DOM): 2016
Impressions: Less than 10,000
Guarantee: 30-Day NON-DOA.
Features
* High Speeds upto 7500/sph
* PLC and Servo Control
* HMI with Auto Safety Check
* Operator Friendly
* CE Certified
Specifications
Sheet Size (Max): 41.73″ x 29.13″ (1060 x 740 mm)
Sheet Size (Min): 15.74″ x 14.17″ (400 x 360 mm)
Pile Height (Feeder): 59.05″ (1150 mm)
Pile Height (Delivery): 43.30″ (1100 mm)
Die-Cutting
Die Cutting Size (Max): 40.94″ x 28.74″ (1040 x 730 mm)
Pressure (Max): 300 Tons
Speed (Max): 7500 Sheets Per Hour
Height of Cutting Rules: 0.93″ (23.8 mm)
Chase Size (Inside): 44.09″ x 29.92″ (1120 x 760 mm)
Stock Range: Cardboard 90 ~ 2000 g/m², (E,B LUTE)
Gripper Margin (Min): 0.15″ (4mm)
Power Consumption
Main motor capacity: 11kw
Total power capacity: 23kw
Footprint
Dimensions (LxWxH): 19.68′ x 13.77′ x 7.87′ ft (6000 x 4200 x 2400 mm)
Weight: 35,274 Lbs (16000 Kg)
Applications
Creasing, Die Cutting, Embossing, Stripping on Paper, Cardboard, Corrugated Board and Plastics etc, Folding Boxes, Labels, Leaflets, Book Covers, Hanging Tags, and More.
Condition: Installed as a demonstration unit in Southern California, This is Like-New machine that has not been put into production. Currently installed, underpower, and operating. It can be seen running by an appointment and deposit only. You will not find a die-cutter this new, for this price. Original purchase price is over $260,000 for this machine from the manufacturer.
Compare this machine to the following die-cutters: Bobst Die Cutter, Thompson Die Cutter, Heidelberg Die-Cutter, Enko Die-Cutter.
Questions & Answers:
Q: Can this machine been seen running? Can we demo the machine before we decide to purchase?
A: Yes, this machine can be seen running and operating. However, to ensure our time is not wasted we require a deposit of 10% in-order to schedule an appointment for viewing.
Q: If something breaks, How would we get support or parts?
A: This is a very well known brand of die-cutters and we will provide the purchaser with contact details with the manufacturer directly to ensure you are able to get the support you need into the future.
Q: Do you offer transportation and installation?
A: Yes, we have experienced techs and dedicated rigging company that will provide you with a complete turn-key service if you desire. OC Equipment www.ocequipment.com can install in on your floor and bring it up to operating order. Please note that this service would be an additional cost and is not included in the price this machine is listed as.
DEALER PRICE: $165,000.00 Price is FIRM.
