2011 ElTosch Dryer
Discussion in 'Man Roland Printing Presses' started by johnq04, May 29, 2024.
  1. johnq04
    johnq04 Member
    Sep 2023
    5
    louisiana
    Anyone familiar with the following error on the ElTosch Dryer for a 2011 ManRoland 504?
  2. CHOCK
    3,051
    Hi Sir:
    Please review this:
    1) Perform a visual inspection : look for loose and broken wires, improperly seated connectors, loose or
    broken wires
    Dust + dirt + tear +wear
    Edge connectors are a common source of problems( 75% in electronic Problem). Power down the system and remove the PC
    boards. Examine the edge connector
    for contamination and clean - with Eraser pencil and then with contacts cleaner contacts. Reseat any loose components such as
    sockets ICs) . Reseat
    Blessing.
  3. johnq04
    johnq04 Member
    Sep 2023
    5
    louisiana
    Thank you for the response.
    Please describe the location of the PC Boards to examine the edge connectors. Our pressman could not locate.
  4. CHOCK
    3,051
    All printed circuit electronic boards.
    OK?
    Blessings.
  5. drukman
    drukman Senior Member
    Mar 2016
    419
    Bulgaria
    Switch to German. The translation is bad. Most likely a CAN problem.
  6. CHOCK
    3,051
    Did you fix it, according with my steps???
    Let me know.
