Kris
Does anyone know what the sheet arrival timing should be on a 2008 CD102. I have checked the arrival and right as the sheet hits the headstops I am showing around 190°. The feeder is a preset plus and we have recently been having issues with getting sheets to run. When a sheet finally jams it tears off at the headstops and occasionally the grippers have grabbed the sheet anywhere from 3 to 7 inches away from the edge of the sheet. Otherwise we can get the press to run about 11,500 and hour for about 1,000 to 3,000 sheets before this happens. The inconsistency of having getting a bad sheet has me baffled. We only run 60# C1S and I have tried running with stock from two different suppliers and have gotten the same problems on both. Any help is greatly appreciated. Thank you!
