2003 SM74 air cabinet
Discussion in 'Heidelberg Printing Presses' started by swilson513, Sep 28, 2024.
  1. swilson513
    swilson513 Member
    Oct 2009
    91
    USA
    We’re having some issues with feeding that we thank is related to the air cabinet.
    In the cabinet is the main compressor and 2 turbine type blowers that have 2.5” hoses on them that run down to the bottom and connects to assuming some type of manifold. What’s the turbines supplying all the air for?
    Our problem seems that we don’t have enough air blast at the back of the sheet to separate them, we thought that air was from the main compressor. Does the turbines contribute to the air?
  2. ashok kumar
    ashok kumar Senior Member
    Nov 2017
    246
    india
    Main compreasor(m5)give blast air and vacuum to feeder .
    M6 /m7(trubine type) gives vaccum and air in delivery.
    For more clarity pls send us machine model year as well as pic of airstar
  3. Jack liston
    Jack liston Senior Member
    Sep 2019
    331
    Connecticut
    It's not uncommon for hose to break at the manifold you need to go under catwalk and look at hoses coming out of the air cabinet they are marked for blast and suction refer to the manual.you may have leaks all along hose.
  4. swilson513
    swilson513 Member
    Oct 2009
    91
    USA
    Thanks, I completely overlooked the delivery since I was focusing on the feeder.
    Any idea what type of pressure or vacuum we should have at main compressor.
  5. Adil
    Adil Senior Member
    Nov 2021
    1,334
    Casablanca
    The vacuum compressor is used to supply the margin and the reception with blowing and suction air concerning the turbines, they are used to give an air cushion between the printing groups to avoid friction of the sheets
    komori92 likes this.
