2 colour 2005 PM 74
Discussion in 'Heidelberg Printing Presses' started by Alistair Tinsley, Sep 24, 2024.
  1. Alistair Tinsley
    Alistair Tinsley Member
    Apr 2023
    94
    N Ireland
    How do I combat the lines.
    If I turn down ink amount at this point I do not get enough on main body.
    I have isolation off.
    Help appreciated
    Thank you
  2. Beguin
    Beguin Senior Member
    Jan 2020
    365
    Côté d'ivoire
    Hello dear sir, please check if the problem does not come from your plate or take another job different from this one to see if the line is still there. If the line is still there, please check the ink touch rollers. Thank you very much
  3. asem alsafady
    asem alsafady Senior Member
    Mar 2016
    184
    Amman Jordan
    Dear Ali
    If you can, try to design a new plate and put two solid areas at both sides as shown in the picture.
    Good luck.
    Adil likes this.
  4. Adil
    Adil Senior Member
    Nov 2021
    1,086
    Casablanca
    Hi ali
    What asem alsafafy say is the good solution for your problem ,tested and confirmed .
    Good luck
  5. mantman
    mantman Senior Member
    Nov 2015
    283
    Greece
    Ink take off bars will help -as Asem mentioned-
