09-3163
Discussion in 'Xerox iGen3, iGen4, & iGen5 Digital Presses' started by peels, Sep 13, 2018.
  1. peels
    peels tree killer :)
    Dec 2010
    1,048
    southeast iowa, usa
    inboard ETACS LED Out of range. Ive cleaned them, will occasionally pass 951, then run for awhile but many times its this error. if I let it sit too long, it wont cycle up. 9-1100.... so the cycle begins again.
    got a 9-3110 once.
    Tried: new belt, pre clean corotron, random cleaning, checking, reboot.
    ideas? Feel like thats a sensor thing, not an actual problem. anything else to check?
  2. peels
    Dec 2010
    1,048
    southeast iowa, usa
    Well it was running when I left, so I let it print... 1400 sheets... the black slowly fades to nothing. HAlf the stack only has color,no black lol
    thebottles empty without giving notification. Ive never seen that before. anyone else? and could that be the problem?
  3. cisco605
    cisco605 Member
    Jan 2012
    33
    usa
    check the connection on the inboard black etac. make sure its clean. if that does not work replace it and you will be good to go. As far as the toner bottle probs just the sensor .
