00.780.2290 counter
Discussion in 'Heidelberg Printing Presses' started by swilson513, Nov 13, 2019.
  1. swilson513
    swilson513 Member
    Oct 2009
    80
    USA
    On our MO both the resettable counter and totalizer seem to have gone bad. Seems odd that they would both go at the same time. When I took the counter out it seems they operate independently making me think that the 24v is the problem. Could someone tell me where the 24v is coming from?
  2. CHOCK
    2,877
    1) Please your schematic diagram, the +24Vdc is coming from Rectifier N1.
    2) However if you do not have: measure the Fuses:e5+e14, for 4 Amps.,after secondary of main transformer m6.
    3) Look for loose wires, or corroded,: a) tight very well b) clean it with special contacts cleaner spray.
  3. junker1984
    junker1984 Senior Member
    Jan 2010
    1,036
    US, Midwest
    Roller switch under feed board (register plate).
