Cp2000 got stuck
Discussion in 'Heidelberg Printing Presses' started by Michaelsh, Jun 4, 2023.
  1. Michaelsh
    Michaelsh New Member
    Jun 2023
    Israel
  2. Beguin
    Beguin Senior Member
    Jan 2020
    348
    Côté d'ivoire
    hello dear sir, be sure to go to the second hard drive or remove the hard drives and put them back or this requires reinstalling the software or the hard drives have taken a hit.
  3. Joe Burger
    Joe Burger Member
    May 2023
    14
    Germany
    Yes, switch to second hard drive when working on first. that helps.
  4. diegoeze
    diegoeze Member
    Mar 2019
    26
    Argentina
    Hi Beguin. You must turn off the machine . Then you have to open the cover and look for a sticker . This says don't touch or something in any equipment MCO MC5 . Switch to the second HDD . And turn on the press. With this process cp2000 will start up. You have to put in contact with Heidelberg to replace HDD or IPC . If you don't have experience in that equipment DON'T TOUCH HDD.
  5. Adil
    Adil Senior Member
    Nov 2021
    866
    Casablanca
    Hi sir .
    before the machine hangs on this display is a black page of the bios displayed at the start quickly and setteint if so, please make me a video to be able to read what the black page displays as an error.
    Let me know ,
  6. diegoeze
    diegoeze Member
    Mar 2019
    26
    Argentina
    You must check data cable connect between ipc and rgp. It looks HDD is working because licenses are been loaded again and again .... Let us know
  7. Adil
    Adil Senior Member
    Nov 2021
    866
    Casablanca
    If swotching to second hard disc not fix the issue , then we can talk about setting of bios on the ipc , youneed to check date setting on the bios .
  8. Adil
    Adil Senior Member
    Nov 2021
    866
    Casablanca
    That s why i told you sir to take video of the black page when the machine start to see what happend
