GTO 52-4 roller hanger removal
Discussion in 'Heidelberg Printing Presses' started by White rabbit, Aug 16, 2021.
  1. White rabbit
    White rabbit Member
    Apr 2013
    72
    Hi all,
    I am wondering what kind of nightmare i am looking at to remove a form roller hanger from a GTO-52. The pins that hold the roller bearing are worn on the yellow form, to the point the roller bounces. The stationary pin needs to be replaced, or is it possible to rotate it without removing the hanger ?
    Thanks for any thoughts.
  2. Travis Young
    Travis Young Member
    Oct 2019
    98
    Victoria Australia
    If you pull the rollers out can you get a set of vice grips on it?
    I reckon you could get the pin to spin around a bit if you got a good grip on it.
    I could be totally wrong of course.
    Or cut a strip of coke can and wrap it around the pin.
  3. junker1984
    junker1984 Senior Member
    Jan 2010
    1,036
    US, Midwest
    Hey White Rabbit, There are far too many steps to removal to convey on a platform such as this. Travis mentioned a solution I'd never considered, but unless you shim roller bearings outwards,(Heidelberg sells shim rings in various thicknesses) the side to side motion will wear the aluminum in short time. If you've not noticed, there is the sliding pin, the eccentric pin (locked by means of a set screw which is difficult, nay...impossible, to access without rollers removed) and the fixed pin. Yes, you can try to spin the fixed pin with vice grip, but that never worked out for me.
    asem alsafady likes this.
  4. ziggy33
    ziggy33 Senior Member
    Jul 2010
    451
    Rice Lake WI
    Just replaced the Journels on my GTO Cyan Water unit. It was a 2 man job that took 5 hours that was for one set of housings on one form roller. They are relatively easy to do as long as you know what your doing just time consuming. Unless you replace the journel you will always have this issue.
    I would not recommend doing it yourself if you have never done it before.
    Also when ordering Journels you have to have your serial number handy or they will send you the wrong part, cant just go by the part number in the book.
  5. White rabbit
    White rabbit Member
    Apr 2013
    72
    Thanks for the input. Im going to look at different bearings, or maybe shim somehow. If that fails, ill bet there is a private H mechanic somewhere that will do it.
  6. junker1984
    Jan 2010
    1,036
    US, Midwest
    Could be. Where are you located?
  7. mantman
    mantman Senior Member
    Nov 2015
    274
    Greece
    Travis can you use pepsi can? ;)
  8. junker1984
    Jan 2010
    1,036
    US, Midwest
    Pepsi can won’t work, must use beer can.
    ziggy33 and alibryan like this.
  9. alibryan
    alibryan Senior Member
    May 2014
    220
    Somewhere
    Immediately after consumption.
    ziggy33 and junker1984 like this.
  10. mantman
    Nov 2015
    274
    Greece
    Err 4 col press so 4 beers....hmmmm too much beer for one man :p
    ziggy33 likes this.
  11. junker1984
    Jan 2010
    1,036
    US, Midwest
    Good one, Mantman!
